LG MP58VQ 22" 1920x1080 5ms VGA DVI HDMI LED Monitor
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: C0MJWS00 Mfr#: 22MP58VQ
The IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle.
LG 22MP58VQ - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1976)
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
51.01 cm x 18.68 cm x 39.53 cm
2.9 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class B
31 kWh
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1976)
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Picture in picture, HDCP, Picture Mode, SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, SIX Axis Control, Joystick, Smart Energy Saving technology, Black Stabilizer, Response Time Control, Intelligent Auto, My Display Preset, Sleek Cut Design, Auto Power Off, Color Weakness Mode, Mega DFC
51.01 cm x 18.68 cm x 39.53 cm - with stand
2.9 kg
VGA , HDMI , DVI-D , Headphones
Mechanical
Tilt
Tilt Angle
-2/+15
Key lock
Input Voltage
21 W
Power Consumption (Typical)
24 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 51.01 cm - depth: 18.68 cm - height: 39.53 cm - weight: 2.9 kg , Without stand - width: 51.01 cm - depth: 8.68 cm - height: 30.84 cm - weight: 2.5 kg
