LG LV340C 32" Commercial Lite TV
Quicklinx: DWCNWS00 Mfr#: 32LV340C.AEK
  • 1080p
Public Display Mode
From channel selection to volume level, you can control the TV settings in public areas. Public Display Mode also enables you to restore default settings, as required, on the TVs.
*RS-232C Control *
Via the TV's RS-232C port, you can remotely control power and volume settings simultaneously.
WOL (Wake on LAN)
WOL (Wake on LAN) helps you remotely turn on TVs over the internet. Connect TVs and a PC in the same network, and send Magic Packet program to the MAC addresses of registered TVs. Then, it will wake up the TVs via LAN port.
Lock Mode
Lock Mode blocks external input signals with non-compliant content. This is a useful feature for preventing misuse of TVs in various facilities or public spaces.
Self Diagnosis
Self Diagnosis enables engineers and IT to engineers to analyze the data and identify technical issues quickly and easily through a USB memory device.
USB Auto Playback+
Create a media playlist of your choosing (video, music, and/or images) via USB Auto Playback+. Save it to a USB memory device, and then simply connect the USB memory device to the TV to stream your playlist sequentially.
SuperSignTM C
With SuperSign C, LG's signage management software, you can control and remotely monitor via the LAN port.
Welcome Screen (Splash Image)
Display a customized greeting message with your business name/logo on the TV when it is turned on.
USB Cloning
Clone your UV340C's with efficiency and ease. The USB Cloning feature allows you to simply copy the TV settings to all the UV340C's using a USB memory device (sold separately).
LG Commercial Lite 32LV340C LV340C series - 32" LED-backlit LCD TV - Full HD - for digital signage / hospitality
LED-backlit LCD TV
Diagonal Class
32"
Commercial Use
Yes - digital signage / hospitality
Resolution
1920 x 1080
Display Format
1080p
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15)
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Analogue TV Tuner
PAL, SECAM
Commercial Features
Screen welcome message, Multi remote control, Lock Mode, SNMP support, Self Diagnosis, Crestron Connected Certified
Settings Cloning Capability
Picture Enhancements
Triple XD Engine
Speaker System
2 speakers
Platform
Crestron
USB
Voltage
Energy Class
Class A+
53.5 Watt
Power Consumption (On mode)
30 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
42 kWh
73.9 cm x 16.8 cm x 47.2 cm
4.9 kg
LED-backlit LCD TV
Energy Class
Class A+
53.5 Watt
30 W
42 kWh
Diagonal Class
32"
Commercial Use
Series
LV340C series
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Modes
Hotel mode
Triple XD Engine
Dimensions
With stand
73.9 cm
16.8 cm
47.2 cm
4.9 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
24p Technology
24p Real Cinema
Direct-lit LED
Brightness
240 cd/m²
Pull-Down Compensation
3:3
Commercial Features
Operation Hours / Days
16 / 7
One Channel Map, security lock slot (cable lock sold separately), RJP Compatible, Motion eye care, Scheduler
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Media Player
USB Port
USB Ports Qty
1
Audio System
Speaker System
2 speakers
Output Power / Total
10 Watt
Clear Voice III technology
Speakers
2 x speaker - 5 Watt
Network & Internet Multimedia
LAN
Connector Type
HDMI input - side , USB 2.0 - side , Headphone output - side , Composite video input - rear , Component video input - rear , Audio line-in - rear , HDMI input - rear , Digital audio output (optical) - rear , VGA input - rear , Audio line-in - rear , Serial - rear , LAN - rear , Speakers output - rear
Internet of Things (IoT)
Platform
Crestron
CB, CU-TR
Power supply
Input Voltage
0.3 Watt
Auto On/Off
Smart energy saving, WOL (Wake on LAN)
Width (Shipping)
81.2 cm
Depth (Shipping)
14.2 cm
Height (Shipping)
51 cm
Weight (Shipping)
6.1 kg
