LG G6 Astro Black
Key Features
Next Generation of Design
5.7" QHD+ FullVision Display
Wide Angle Front Camera
Dual 13MP Rear Cameras
Square Camera Mode
Dolby Vision™ & HDR10 Supported
The surprisingly large FullVision display into a sleek device provides more room for text, browsing, and wider view when playing games. The 18:9 aspect ratio and QHD Plus resolution also allow superior picture quality for a more engaging viewing experience.
Get the bigger picture with front camera no matter what the subject is!
Capture all of life’s breathtaking views with the dual 13MP rear-facing cameras in the LG G6.
Square Camera Mode
Have more fun with photos and videos using one of the four different square camera modes.
The LG G6 with Dolby Vision™, HDR10 and a QuadHD+ FullVision display provides an immersive cinematic experience with enhanced contrast and colour.
More to see, less to hold
The surprisingly large FullVision display into a sleek device provides more room for text, browsing, and wider view when playing games. The 18:9 aspect ratio and QHD Plus resolution also allow superior picture quality for a more engaging viewing experience. -
Get more in, leave nothing out
Get the bigger picture with front camera no matter what the subject is. -
Capture the big picture
Capture all of life's breathtaking views with the dual rear-facing cameras in the LG G6. -
Square up and share
Have more fun with photos and videos using one of the four different square camera modes. -
Transform your mobile viewing experience
The LG G6 with Dolby Vision, HDR10 and a QuadHD+ FullVision display provides an immersive cinematic experience with enhanced contrast and color. -
Water and dust resistant
Take the LG G6 just about anywhere without worry thanks to its outstanding water and dust resistance. -
Next level audio recording
Capture fuller, richer, higher-quality sound with the two high AOP mics and high-fidelity recording capability of the LG G6. -
No more worries and enjoy your fame
The LG G6 invites you to the next level of gaming experience, fully supported by Vulkan and allows you not to worry about battery left thanks to the Game Battery Saver. You can also adjust each indicator such as resolution, frame and battery on individual needs.
- LG G6 H870 - platinum - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- H870
- Display
- LCD display - 2880 x 1440 pixels - 5.7" - 564 ppi - TFT - HDR - Corning Gorilla Glass 3 (scratch resistant glass), Corning Gorilla Glass 5 (scratch resistant glass)
- FM radio
- Processor
- Qualcomm Snapdragon 821 MSM8996 Pro / 2.35 GHz (quad-core) - 64-bit
- Memory
- RAM 4 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 2 TB
- Operating System
- Android 7.0 Nougat
- Main Camera
- 13 Megapixel - telephoto lens - f/1.8 - focus: automatic
- Second Camera
- 13 Megapixel - wide-angle lens - f/2.4
- Front Camera
- 5 Megapixel - wide-angle lens - f/2.2
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Standby Time
- Up to 140 hours
- Protection
- Shockproof, dustproof, splashproof, scratch-resistant, water-resistant
- Platinum
- 71.9 mm x 7.9 mm x 148.9 mm
- 163 g
- Specific Absorption Rate (SAR)
- 0.393 W/kg (head) , 1.12 W/kg (body)
- Product Type
- Smartphone
- H870
- Form Factor
- Touch
- Protection
- Integrated Components
- FM radio
- 71.9 mm
- 7.9 mm
- 148.9 mm
- 163 g
- Body Colour
- Platinum
- Body Material
- Metal, Gorilla glass 5
- SAR Value
- 1.12 W/kg (body), 0.393 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Intelligent Assistant
- Google Assistant
- Navigation
- GPS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Payment Technology
- Android Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
- Supported Email Protocols
- POP3, IMAP4, SMTP
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1800, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 28, Band 38, Band 40
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, gyro sensor, hall sensor
- Security Devices
- Android Enterprise Recommended
- Additional Features
- TTY compatible, software updates FOTA (Firmware Over The Air), multitasking, HD Voice, Wi-Fi Calling, Wireless Emergency Alerts function, QuickMemo+ function, Smart Cleaning, Alarm Clock, Noise suppression by NXP Solution, Fast Charging, HD audio recorder, DriveMode, TTD compatible
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, MP3, AAC +, OGG, eAAC+, MIDI, MP4, AMR-WB, AMR-NB
- Supported Digital Video Standards
- MKV, FLV, AVI, M-JPEG, XviD, MPEG-4, WMV, ASF, 3GP, H.263, TS, WebM, VP8, VP9, Theora, OGM, MPEG4-ASP, MPEG4-SP, H.264 BP, H.264 MP, H.264 HP, H.265 Main, H.265 Main10
- Processor Number
- MSM8996 Pro
- Clock Speed
- 2.35 GHz
- Processor Core Qty
- Quad-core
- 64-bit Architecture
- RAM
- 4 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 2 TB
Front Camera
- Sensor Resolution
- 5 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.2
- Camera Modes
- Time-lapse mode, Gesture Shot, Share Shot function, Auto Shot, GIF animation function, Popout Mode, Square Camera
- Light Source
- Flash
- Electronic Image Stabiliser (EIS)
Main Camera
- Sensor Resolution
- 13 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Telephoto lens
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Digital Zoom
- 8x
- Special Effects
- HDR
- Camera Modes
- Slow motion video, Panorama, Time-lapse mode, BurstShot, manual mode, Cheese Shot, Food mode, Timer Shot, Snap video mode, Popout Mode, 360 Panorama mode
- Light Source
- LED light
- Video Resolutions
- 3840 x 2160 (4K)
- Phase Detect Auto-Focus (PDAF), Closed loop processing, geotagging, RAW image capture, camera roll view, Steady Record 2.0, Square Camera
Second Camera
- Sensor Resolution
- 13 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.4
Display
- LCD display
- Technology
- TFT
- Diagonal Size
- 5.7"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 564 ppi
- Colour Depth
- 16.7 million colours
- HDR
- HDR Technology
- HDR10
- Enhancement Technology
- Dolby Vision
- Protection
- Display Languages
- Danish, Hungarian, Czech, Icelandic, Basque, Croatian, Slovenian, Slovak, Galician, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Romanian, Catalan, Chinese, Korean, Bosnian
- In-Cell Display Technology, FullVision display
- Connector Type
- Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
- Technology
- Lithium Ion
- Capacity
- 3300 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 3.0
- Standby Time
- 140 hours
- Run Time Details
- Standby: up to 140 hrs
- IEC 60529 IP68, MIL-STD 810G
- Included Accessories
- Power adapter, USB-C cable
- Max Depth of Water Resistance
- 1.5 m
