LG G6 5.7" 4GB RAM 32GB 13MP Sim-Free Android Smartphone - Red
Quicklinx: DJGQWS00 Mfr#: LGH870.AGBRRP
Colours:
  • microSDHC
  • Android
LG G6 Astro Black
Key Features
Next Generation of Design
5.7" QHD+ FullVision Display
Wide Angle Front Camera
Dual 13MP Rear Cameras
Square Camera Mode
Dolby Vision™ & HDR10 Supported
The surprisingly large FullVision display into a sleek device provides more room for text, browsing, and wider view when playing games. The 18:9 aspect ratio and QHD Plus resolution also allow superior picture quality for a more engaging viewing experience.
Get the bigger picture with front camera no matter what the subject is!
Capture all of life’s breathtaking views with the dual 13MP rear-facing cameras in the LG G6.
Square Camera Mode
Have more fun with photos and videos using one of the four different square camera modes.
The LG G6 with Dolby Vision™, HDR10 and a QuadHD+ FullVision display provides an immersive cinematic experience with enhanced contrast and colour.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
  • More to see, less to hold
  • Get more in, leave nothing out
    Get the bigger picture with front camera no matter what the subject is.
  • Capture the big picture
    Capture all of life's breathtaking views with the dual rear-facing cameras in the LG G6.
  • Square up and share
  • Transform your mobile viewing experience
    The LG G6 with Dolby Vision, HDR10 and a QuadHD+ FullVision display provides an immersive cinematic experience with enhanced contrast and color.
  • Water and dust resistant
    Take the LG G6 just about anywhere without worry thanks to its outstanding water and dust resistance.
  • Next level audio recording
    Capture fuller, richer, higher-quality sound with the two high AOP mics and high-fidelity recording capability of the LG G6.
  • No more worries and enjoy your fame
    The LG G6 invites you to the next level of gaming experience, fully supported by Vulkan and allows you not to worry about battery left thanks to the Game Battery Saver. You can also adjust each indicator such as resolution, frame and battery on individual needs.
LG G6 H870 - raspberry rose - 4G smartphone - 32 GB - GSM
4G smartphone
Manufacturer Model Number
H870
Display
LCD display - 2880 x 1440 pixels - 5.7" - 564 ppi - TFT - HDR - Corning Gorilla Glass 3 (scratch resistant glass), Corning Gorilla Glass 5 (scratch resistant glass)
FM radio
Qualcomm Snapdragon 821 MSM8996 Pro / 2.35 GHz (quad-core) - 64-bit
RAM 4 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 2 TB
Operating System
Android 7.0 Nougat
Main Camera
13 Megapixel - telephoto lens - f/1.8 - focus: automatic
Second Camera
13 Megapixel - wide-angle lens - f/2.4
Front Camera
5 Megapixel - wide-angle lens - f/2.2
Service Provider
Not specified
SIM Card
Single-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Standby Time
Up to 140 hours
Protection
Shockproof, dustproof, splashproof, scratch-resistant, water-resistant
Raspberry rose
71.9 mm x 7.9 mm x 148.9 mm
163 g
0.393 W/kg (head) , 1.12 W/kg (body)
Smartphone
H870
Touch
Protection
Integrated Components
FM radio
71.9 mm
7.9 mm
148.9 mm
163 g
Body Colour
Raspberry rose
Body Material
Gorilla glass 5
SAR Value
1.12 W/kg (body), 0.393 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 7.0 Nougat
Intelligent Assistant
Google Assistant
Navigation
GPS
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Payment Technology
Android Pay
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Supported Email Protocols
POP3, IMAP4, SMTP
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1800, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 28, Band 38, Band 40
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
Bluetooth Profiles
HFP, HSP, OPP, PAN, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, gyro sensor, hall sensor
Security Devices
Fingerprint reader
Android Enterprise Recommended
Additional Features
TTY compatible, software updates FOTA (Firmware Over The Air), multitasking, HD Voice, Wi-Fi Calling, Wireless Emergency Alerts function, QuickMemo+ function, Smart Cleaning, Alarm Clock, Noise suppression by NXP Solution, Fast Charging, HD audio recorder, DriveMode, TTD compatible
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, MP3, AAC +, OGG, eAAC+, MIDI, MP4, AMR-WB, AMR-NB
Supported Digital Video Standards
MKV, FLV, AVI, M-JPEG, XviD, MPEG-4, WMV, ASF, 3GP, H.263, TS, WebM, VP8, VP9, Theora, OGM, MPEG4-ASP, MPEG4-SP, H.264 BP, H.264 MP, H.264 HP, H.265 Main, H.265 Main10
Processor Number
MSM8996 Pro
Clock Speed
2.35 GHz
Processor Core Qty
Quad-core
64-bit Architecture
RAM
4 GB
Internal Memory Capacity
32 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 2 TB
Front Camera
Sensor Resolution
5 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/2.2
Camera Modes
Time-lapse mode, Gesture Shot, Share Shot function, Auto Shot, GIF animation function, Popout Mode, Square Camera
Light Source
Flash
Electronic Image Stabiliser (EIS)
Main Camera
Sensor Resolution
13 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Telephoto lens
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Digital Zoom
8x
Special Effects
HDR
Camera Modes
Slow motion video, Panorama, Time-lapse mode, BurstShot, manual mode, Cheese Shot, Food mode, Timer Shot, Snap video mode, Popout Mode, 360 Panorama mode
Light Source
LED light
Video Resolutions
3840 x 2160 (4K)
Phase Detect Auto-Focus (PDAF), Closed loop processing, geotagging, RAW image capture, camera roll view, Steady Record 2.0, Square Camera
Second Camera
Sensor Resolution
13 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/2.4
Display
LCD display
TFT
Diagonal Size
5.7"
Display Resolution
2880 x 1440 pixels
Display Format
QHD+
Pixel Density
564 ppi
Colour Depth
16.7 million colours
HDR
HDR Technology
HDR10
Enhancement Technology
Dolby Vision
Protection
Display Languages
Danish, Hungarian, Czech, Icelandic, Basque, Croatian, Slovenian, Slovak, Galician, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Romanian, Catalan, Chinese, Korean, Bosnian
In-Cell Display Technology, FullVision display
Connector Type
Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
Lithium Ion
3300 mAh
Fast Charging Technology
Qualcomm Quick Charge 3.0
Standby Time
140 hours
Run Time Details
Standby: up to 140 hrs
IEC 60529 IP68, MIL-STD 810G
Power adapter, USB-C cable
Max Depth of Water Resistance
1.5 m
