Perfect for multitasking and entertaining, the LG 21:9 UltraWide is always the right choice. A full range of 21:9 UltraWide monitors, both curved and flat, are available to meet your needs.
The 21:9 UltraWide QHD (3440 x 1440) display enables you to stretch the limits of screen real-estate. With the IPS display, visual comfort is guaranteed while ensuring vivid and accurate color expression.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or RGB color code through a sRGB over 99% color space and IPS's accurate color expression. Since color calibration tests are conducted on the production line and the Hardware Calibration Ready with a built-in scaler to directly adjust the color setting, its color accuracy is guaranteed with tools for perfect color management.
21:9 UltraWide rules
Perfect for multitasking and entertaining, the LG 21:9 UltraWide is always the right choice. A full range of 21:9 UltraWide monitors, both curved and flat, are available to meet your needs. -
21:9 UltraWide QHD on IPS display
The 21:9 UltraWide QHD (3440 x 1440) display enables you to stretch the limits of screen real-estate. With the IPS display, visual comfort is guaranteed while ensuring vivid and accurate color expression. -
Flawless color expression
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or RGB color code through a sRGB over 99% color space and IPS's accurate color expression. Since color calibration tests are conducted on the production line and the Hardware Calibration Ready with a built-in scaler to directly adjust the color setting, its color accuracy is guaranteed with tools for perfect color management. -
Advanced tech design
The adjustable stand with Height and Tilt function allows you to provide more comfortable working conditions. -
USB 3.0 quick charge
Charge the battery of a connected device quickly using the USB 3.0 port on the product. -
The big convergence of FreeSync & 21:9 UltraWide QHD
The FreeSync era has come. On the 34-inch 21:9 UltraWide QHD, you can experience the next level of gaming without any tearing and stuttering.
- LG 34UM88C - LED monitor - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class B
- Energy Consumption per Year
- 79 kWh
- Power Consumption (On mode)
- 54 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey), 14 ms (On/Off)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% Adobe RGB (CIE 1931)
- Input Connectors
- 2xHDMI, DisplayPort
- Height, tilt
- Voltage
- AC 120/230 V
- 82.99 cm x 25.24 cm x 42.89 cm
- 8.4 kg
- FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0
- Display Type
- Energy Class
- Class B
- 79 kWh
- Diagonal Size
- 34"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture in picture, HDCP, Picture Mode, game mode, On-screen Digital Controls, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Mercury free, PBP, MaxxAudio, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Mega DFC, USB 3.0 Quick Charge
- 82.99 cm x 25.24 cm x 42.89 cm - with stand
- 8.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- 2 x HDMI , Headphones , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Height, tilt
- Tilt Angle
- -5/+20
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Key lock
- Included Accessories
- Stand
- Input Voltage
- AC 120/230 V
- 54 W
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Sleep
- 1.2 Watt
- 0.3 Watt
- OS Required
- Microsoft Windows
- Dimensions & Weight Details
- With stand - width: 82.99 cm - depth: 25.24 cm - height: 42.89 cm - weight: 8.4 kg , Without stand - width: 82.99 cm - depth: 4.92 cm - height: 37.98 cm - weight: 6.3 kg
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
