Your basket is empty
LG Electronics UM88C 34" 3440x1440 5ms HDMI Display Port IPS Monitor
Quicklinx: C0MVWS00 Mfr#: 34UM88C
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI
11 in stock
£551.02 ex VAT
£661.22 inc VAT
Perfect for multitasking and entertaining, the LG 21:9 UltraWide is always the right choice. A full range of 21:9 UltraWide monitors, both curved and flat, are available to meet your needs.
The 21:9 UltraWide QHD (3440 x 1440) display enables you to stretch the limits of screen real-estate. With the IPS display, visual comfort is guaranteed while ensuring vivid and accurate color expression.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or RGB color code through a sRGB over 99% color space and IPS's accurate color expression. Since color calibration tests are conducted on the production line and the Hardware Calibration Ready with a built-in scaler to directly adjust the color setting, its color accuracy is guaranteed with tools for perfect color management.
LG 34UM88C - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
54 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms (On/Off); 5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
82.99 cm x 25.24 cm x 42.89 cm
8.4 kg
FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class B
79 kWh
54 W
Diagonal Size
34"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, HDCP, Picture Mode, game mode, On-screen Digital Controls, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Mercury free, PBP, MaxxAudio, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, FreeSync Technology, 99% Adobe RGB (CIE 1931) colour gamut, split screen 2.0, My Display Preset, Mega DFC, USB 3.0 Quick Charge
82.99 cm x 25.24 cm x 42.89 cm - with stand
8.4 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , Headphones , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
Key lock
Stand
AC 120/230 V
65 Watt
Power Consumption Sleep
1.2 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows
Dimensions & Weight Details
With stand - width: 82.99 cm - depth: 25.24 cm - height: 42.89 cm - weight: 8.4 kg , Without stand - width: 82.99 cm - depth: 4.92 cm - height: 37.98 cm - weight: 6.3 kg
C0MV C2G HDMI to DisplayPort Adapter Converter In Stock £36.75
C0MV C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.61
C0MV C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £10.09
C0MV C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £18.63
C0MV C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.55
Diagonal Size: 34in
Response Time: 5ms
Interfaces: HDMI
Brand: LG Electronics
Price Range Ex VAT: 500 - 750
