4K resolution
4K Ultra HD resolution provides outstanding picture quality. It is four times larger than Full HD, allowing it to display the finest details that remain clear even when the picture is viewed from a short distance. With 4K resolution, TV viewing is accompanied by a whole new emotion, brought about by the extraordinary precision of the reproduction of details. -
Scaling up to 4K resolution
The 4K Ultra HD TV allows you to enjoy high picture quality from any source. It is equipped with the 4K Upscaler image scaling function, thanks to which TV broadcasts, movies and sports broadcasts with standard definition can be displayed with quality close to 4K. Thus, even with standard definition content, the finest image details can be admired. -
Compact and slim Ultra Slim design
The Ultra Slim 4K TV guarantees the highest picture quality while impressing with its minimal screen thickness. The compact and slim design does not compromise either picture quality or user comfort. Thanks to it, the TV blends wonderfully into the surroundings without disturbing the aesthetics of the interior. Great technology hidden in a compact is a source of unique experiences that enrich life. -
4K 60P HEVC decoder
The LG Ultra HD TV is equipped with a HEVC decoder, which allows for crystal clear images and motion reproduction at 60 frames per second. Now you can enjoy a pristine picture with great resolution and perfect colors, even when watching content streamed from the Internet or played from an external device. Regardless of the source of the content, the TV allows you to enjoy a seamless, high-quality viewing experience.
- LG 60UF695V 60" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 60"
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- Ultra Clarity Index 900
- 24p Technology
- 24p Real Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight local dimming
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Internet Streaming Services
- Smart TV Premium
- Speaker System
- 2 speakers
- Sound Effects
- Virtual Surround Plus
- USB
- 3 ports
- Included Accessories
- Universal remote
- Energy Class
- Class A+
- Power Consumption (On mode)
- 100 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 146 kWh
- Dimensions (WxDxH) - without stand
- 134.1 cm x 3.91 cm x 78.8 cm
- 25.8 kg
- Product Type
- Energy Class
- Class A+
- 100 W
- 146 kWh
- Diagonal Class
- 60"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- HDCP Compatible
- Design
- CINEMA SCREEN design
- Dimensions
- Without stand
- 134.1 cm
- 3.91 cm
- 78.8 cm
- 25.8 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 24p Technology
- 24p Real Cinema
- Time-shift, Resolution Upscaler, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Media Player
- Supported Video Formats
- DivX HD, HEVC
- Supported Audio Formats
- MP3, PCM, AC3, AAC, HE-AAC, E-AC3, DTS
- Supported Pictures Formats
- JPG, MPO, JPS
- USB Port
- USB Ports Qty
- 3
Remote Control
- Universal remote
- LG Magic Motion Remote Control Ready
Audio System
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, built-in Dolby Digital decoder, Optical Sound Sync
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
- Smart TV Premium
- Application Store
- LG App Store
- DLNA
- Connector Type
- Composite video / component video input - rear , Audio line-in - rear , MHL/HDMI input - side , SCART - rear , 3 x USB 2.0 - side , Digital audio output (optical) - rear , LAN - rear , Serial - rear , Headphones - rear , 2 x MHL/HDMI input - rear
- Power Device
- Power supply
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 134.1 cm x 3.91 cm x 78.8 cm x 25.8 kg , Panel with stand - 134.1 cm x 27.1 cm x 83.6 cm x 26.5 kg
