LG Electronics Ultra HD Smart LED TV 3840 x 2160 Resolution Black
Quicklinx: BVPRWS00 Mfr#: 60UF695V
Marketing description is not available.
  • 4K resolution
    4K Ultra HD resolution provides outstanding picture quality. It is four times larger than Full HD, allowing it to display the finest details that remain clear even when the picture is viewed from a short distance. With 4K resolution, TV viewing is accompanied by a whole new emotion, brought about by the extraordinary precision of the reproduction of details.
  • Scaling up to 4K resolution
    The 4K Ultra HD TV allows you to enjoy high picture quality from any source. It is equipped with the 4K Upscaler image scaling function, thanks to which TV broadcasts, movies and sports broadcasts with standard definition can be displayed with quality close to 4K. Thus, even with standard definition content, the finest image details can be admired.
  • Compact and slim Ultra Slim design
    The Ultra Slim 4K TV guarantees the highest picture quality while impressing with its minimal screen thickness. The compact and slim design does not compromise either picture quality or user comfort. Thanks to it, the TV blends wonderfully into the surroundings without disturbing the aesthetics of the interior. Great technology hidden in a compact is a source of unique experiences that enrich life.
  • 4K 60P HEVC decoder
    The LG Ultra HD TV is equipped with a HEVC decoder, which allows for crystal clear images and motion reproduction at 60 frames per second. Now you can enjoy a pristine picture with great resolution and perfect colors, even when watching content streamed from the Internet or played from an external device. Regardless of the source of the content, the TV allows you to enjoy a seamless, high-quality viewing experience.
LG 60UF695V 60" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
60"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
Ultra Clarity Index 900
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
PC Interface
Mobile High-Definition Link (MHL)
HDCP Compatible
LCD Backlight Technology
LED backlight local dimming
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Internet Streaming Services
Smart TV Premium
Speaker System
2 speakers
Sound Effects
Virtual Surround Plus
USB
3 ports
Universal remote
Energy Class
Class A+
Power Consumption (On mode)
100 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
146 kWh
134.1 cm x 3.91 cm x 78.8 cm
25.8 kg
Energy Class
Class A+
100 W
146 kWh
Diagonal Class
60"
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Design
CINEMA SCREEN design
Dimensions
Without stand
134.1 cm
3.91 cm
78.8 cm
25.8 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
24p Technology
24p Real Cinema
Time-shift, Resolution Upscaler, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Media Player
Supported Video Formats
DivX HD, HEVC
Supported Audio Formats
MP3, PCM, AC3, AAC, HE-AAC, E-AC3, DTS
Supported Pictures Formats
JPG, MPO, JPS
USB Port
USB Ports Qty
3
Remote Control
Universal remote
LG Magic Motion Remote Control Ready
Audio System
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in DTS decoder, built-in Dolby Digital decoder, Optical Sound Sync
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
Connect & Share
Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
Smart TV Premium
Application Store
LG App Store
DLNA
Connector Type
Composite video / component video input - rear , Audio line-in - rear , MHL/HDMI input - side , SCART - rear , 3 x USB 2.0 - side , Digital audio output (optical) - rear , LAN - rear , Serial - rear , Headphones - rear , 2 x MHL/HDMI input - rear
Power supply
0.3 Watt
Dimensions & Weight Details
Panel without stand - 134.1 cm x 3.91 cm x 78.8 cm x 25.8 kg , Panel with stand - 134.1 cm x 27.1 cm x 83.6 cm x 26.5 kg
