Your basket is empty
LG Electronics UC98 34" 3440x1440 5ms HDMI Display Port Curved IPS Monitor
Quicklinx: C0MYWS00 Mfr#: 34UC98
Perfect for multitasking and entertaining, the LG 21:9 UltraWide is always the right choice.
LG 34UC98 - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
54 W
Curved Screen
Adaptive Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
QHD 3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms (On/Off); 5 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
2xThunderbolt, 2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
81.76 cm x 23.04 cm x 45.14 cm
7.8 kg
FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0, EDID compatible
Display Type
Energy Class
Class B
79 kWh
54 W
Diagonal Size
34"
Curved Screen
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
QHD 3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Picture Mode, game mode, On-screen Digital Controls, FPS Mode, Flicker Safe, Reader Mode, SIX Axis Control, PBP, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, 99% Adobe RGB (CIE 1931) colour gamut, split screen 2.0, My Display Preset, Auto Power Off, Color Weakness Mode, Mega DFC, USB 3.0 Quick Charge
81.76 cm x 23.04 cm x 45.14 cm - with stand
7.8 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x Thunderbolt , 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Height, tilt
Tilt Angle
-5/+15
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Key lock
Stand
AC 120/230 V
70 Watt
Power Consumption Sleep
1.2 Watt
Microsoft Windows
Dimensions & Weight Details
With stand - width: 81.76 cm - depth: 23.04 cm - height: 45.14 cm - weight: 7.8 kg , Without stand - width: 81.76 cm - depth: 8.87 cm - height: 36.08 cm - weight: 6.2 kg
