LG Electronics Optimus G2 Android Sim Free Handset - Black
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 9214WS00 Mfr#: LGD802.A6GBBK
  • Android
See imagery in vibrant color and clarity. G2's 5.2" full HD IPS display gives you a superior visual experience with true-to-nature colors, sharp text, high-definition details, and a cinema-like 16:9 aspect ratio. Its rich, 423 pixels-per-inch resolution shows off every detail, and its full HD IPS display gives you bright whites and more accurate, lifelike color representation without over-saturation or eye strain. So, whether you are watching a nature show in full HD, viewing a portrait set against a true-blue sky, or shopping for shoes in the perfect shade of red, you will get an authentic view of whatever you are looking at.
You do not need a steady hand to get sharp pictures and smooth videos with G2. Its high resolution, 13 MP camera features breakthrough optical image stabilization technology, which stabilizes your focus while you hold the camera so you get less blur in photosand less shaking in videos. This feature is great for night photography too. Lower light settings require longer exposures, creating the potential for more movement to blur images - but with OIS, you can get amazing low-light shots, even if you can not hold perfectly still. Plus, multi points AF initiates fast and accurate focus for multiple faces or moving objects with 9 AF points, while super resolution lets you zoom in closer without losing quality to ensure detailed, sharp images with 8 times the normal zoom.
  • 5.2" full HD IPS display
  • 13 MP OIS camera
  • High quality sound
    There is a lot of detail behind every sound - and with high quality sound, you will hear and record it all. This feature impacts audio in much the same way that high-resolution video impacts imagery - bringing greater clarity and fidelity, so you will never miss the deep tone of the base, subtle vocal details, or the sweet sound of a power chord. G2 delivers high quality audio - in both recording and listening - without distortion for studio master files, supporting 24-bit, 192 kHz Hi-Fi playback for FLAC and WAV files. Additionally, G2 features multi-mic recording with advanced noise cancellation, so it captures and recorded audio with clear sound even in noisy environments. Experience your music and recordings the way they were meant to be heard with high resolution sound.
  • Qualcomm Snapdragon 800 processor with 2.26 Ghz quad-core CPUs
    Enjoy silky-smooth graphics while watching video orplaying games, browse the web faster, and juggle multiple apps with zero lag time. No matter how you like to use your G2, you will get a more seamless experience powered by Qualcomm Snapdragon 800 Processor with 2.26 Ghz quad-core CPUs. By dividing tasks efficiently between its four cores, G2 can easily run multiple processes at once, delivering up to a 50 percent increase in graphics performance and faster CPU speeds.
  • Long-lasting battery
    G2's 3,000 mAh SiO+ battery gives you surprising power, without compromising style, so you can keep going all day - and look good doing it. The battery's step-design and silicon anode enables maximum storage capacity and efficiency in a super-slim size, compared to traditional Li-ion batteries. Plus, the added GRAM chipset saves battery life with 10% less power consumption.
  • Guest mode
    You are not always the only one using your phone - but with guest mode, you can personalize a user experience for yourself or a guest, controlling which apps and capabilities are available depending on which mode you enable. This feature lets you hand-select the home screen for yourself and a guest, such as a child or a friend, and create separate pattern locks for that user. So you can share your phone whenever you like, and your content and settings stay just how you left them.
  • Audio zooming
    Audio zoom lets you zero in on a specific audio source by zooming in on your subject while recording video. Afterwards, you can hear it more clearly during playback. This unique feature uses three stereo mikes, which amplify sound from the specified angle and deemphasize the surrounding noise, so you can zoom in on the sounds you want to hear, and tune out those you don't.
  • Knockon
    A simple knocking gesture is all it takes. Just knock twice on G2 to gently wake your phone's display without picking it up or pressing the power key. G2 senses the gesture and turns the display on. When your hands are full or when you only have a couple of taps to spare, G2 will help lessen the load.
  • Plug and pop
    Want to listen to music? Just plug in your headphones. Ready to sync files plug in your USB cable. With plug and pop, G2 intuitively shows you the icons for features that require earphones or USB cables when you plug them in, letting you use the apps you want faster.
  • Dual recording/dual camera
    Put yourself in the picture, even if you are the one behind the camera. Dual recording/dual camera lets you activate the front and rear cameras simultaneously, so you can record yourself and your subject at the same time. This fun feature works with both the camera and video camera, using picture-in-picture technology to put your face in any photo or video you are shooting.
  • Tracking zoom
    Focus in on your favorite subject, without losing track of the big picture. Tracking zoom lets you create unique videos with a picture-in-picture frame that highlights your selected subject's movements, while keeping the rest of the scene in view. This feature zooms in on the moving subject you select, and tracks their actions in a separate pane overlapping the background video.
  • Zoom to track
    Zoom to track makes watching videos on your G2 more interactive and fun by letting you selectively zoom in on a subject during playback. Simply select a moving object on your screen while watching a video, and zoom to track zooms in and tracks it throughout the clip. It is like getting behind the camera for a closer look - even after the video has been recorded.
  • Capture plus
    See the big picture when you are surfing the web with capture plus. Instead of a limited screen capture, capture plus lets you take a screen shot of a full web page, with precise border controls. It is a much better way to save online articles, recipes, receipts or other documents you would like to read or print later.
  • Clip tray
    Clip tray operates as a PC-like clipboard that stores pictures, text, and links you would like to reference later. Great for online comparison-shopping or sharing information with friends, it lets you copy and store multiple items in a slide-up clipboard at the bottom of the display, creating a visual collection of information. Add items as you go, and selectively choose which ones to include in an email, post, document, or text message.
LG G2 D802 - black - 4G smartphone - 16 GB - GSM
4G smartphone
Manufacturer Model Number
D802
Display
LCD display - 1920 x 1080 pixels - 5.2" - 423 ppi - IPS
FM radio
Qualcomm Snapdragon 800 2.26 GHz (quad-core)
RAM 2 GB / 16 GB
Operating System
Android 4.2.2 (Jelly Bean)
Main Camera
13 Megapixel focus: automatic
Service Provider
Not specified
Wireless Interface
NFC, Bluetooth, Wi-Fi
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack
70.9 mm x 9.1 mm x 138.5 mm
142 g
0.63 W/kg (head) , 0.5 W/kg (body)
SAR Category (Belgium)
B
Smartphone
D802
Touch
Integrated Components
FM radio
70.9 mm
9.1 mm
138.5 mm
142 g
Body Colour
SAR Value
0.5 W/kg (body), 0.63 W/kg (head)
B
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Navigation
A-GPS
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Supported Email Protocols
POP3, IMAP4
Supported Social Networks and Blogs
Google+
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
Wireless Interface
NFC, Bluetooth 4.0, IEEE 802.11a/b/g/n
WLAN Security
WPA2
Communication Features
Mobile Email client, Internet browser
Phone Features
Phone Functions
Speakerphone, call timer, conference call, flight mode, vibrating alert
Sensors
Accelerometer, proximity sensor, gesture
Additional Features
Radio Data Service (RDS), DLNA Certified, software updates FOTA (Firmware Over The Air), sharing media via DLNA, Face Unlock, Android Beam, QuickMemo function, QSlide function, Wi-Fi Miracast, Live Zooming function, infrared remote control, QTranslator function, Dual Camera function, VuTalk function, Dual Recording, Zerogap technology, QuickRemote function, Guest Mode function, KnockON, Smart Screen function, Slide Aside function, Answer Me function
Organiser
Personal Information Management
Calendar, synchronization with PC, calculator, reminder, alarm clock with snooze, alarm clock
Phone Book Entries Qty
1000
Media Player
Supported Digital Audio Standards
WAV, AAC, MP3, FLAC, AAC +, eAAC+
Supported Digital Video Standards
XviD, MPEG-4, 3GP, H.264, H.263
Sound Enhancements
Hi-Fi Sound support
Clock Speed
2.26 GHz
Processor Core Qty
Quad-core
RAM
2 GB
Internal Memory Capacity
16 GB
Main Camera
Sensor Resolution
13 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Focus Adjustment
Automatic
Digital Zoom
8x
Camera Modes
BurstShot, Time Catch Shot, Shot & Clear
Light Source
Flash
Video Resolutions
1920 x 1080 (1080p)
Sapphire crystal lens cover, Cheese Shutter function, Audio Zooming function, multi-point AF
Display
LCD display
IPS
Diagonal Size
5.2"
Display Resolution
1920 x 1080 pixels
Display Format
Full HD
Pixel Density
423 ppi
Colour Depth
16.7 million colours
Connector Type
USB , Headset jack - mini-phone 3.5mm
Lithium polymer
3000 mAh
Power adapter
