The LG IPS monitor ensures an awesome picture quality, that provides clear images and vivid colors from any angle for your viewing pleasure. It combines the smoothness and solidness in the curved structure. The beauty of the stand is like the icing on the cake.
Sleek Cut design
The Sleek Cut design, the remarkable reduction of depth with body frame, adds sophisticated ambiance for your place. -
Protect your eyes and view in comfort
Did you know, that your eyes are affected by flickers on the monitor, while you may not have seen them? Over time, working, gaming and movie viewing can cause eye strain and fatigue. But, flicker-safe and reader mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero. -
Immerse yourself in the game
The black stabilizer allows you to have better visibility, even in dark scenes. -
Customize your workspace for multitasking
Screen split divides the display into multiple sections for different tasks by resizing the windows on the screen. Its advanced functions have expanded to combine 4 types of picture-in-picture (PIP) mode among different settings. With PIP mode you can work on the main screen, while watching a video in a smaller window floating on the screen. -
Offers improved color vision to color weakness
Color revision algorithms are used to help those with color weakness, who have difficulty distinguishing certain ranges of colors can view all the important content.
- LG 27MP58VQ - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 41 kWh
- Power Consumption (On mode)
- 28 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- High-gloss piano black
- 63.41 cm x 20.47 cm x 46.95 cm
- 4.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, TUV, cUL, EPA 6.0
- Display Type
- Energy Class
- Class A
- 41 kWh
- Diagonal Size
- 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- German, French, Italian, Portuguese, Polish, Finnish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
- 4:3 in Wide, SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, 6-axis colour adjustment, Color Cloning, Black Stabilizer, Sleek Cut Design, Color Weakness Mode
- 63.41 cm x 20.47 cm x 46.95 cm - with stand
- 4.3 kg
- VGA , HDMI , DVI-D , Headphones
Mechanical
- Tilt
- Tilt Angle
- -2/+15
- Included Accessories
- Cable holder
- Cables Included
- 1 x VGA cable , 1 x HDMI cable
- Backlight Life
- 50,000 hours
- MTBF
- 50,000 hour(s)
- Input Voltage
- 28 W
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 63.41 cm - depth: 20.47 cm - height: 46.95 cm - weight: 4.3 kg , Without stand - width: 63.41 cm - depth: 9.11 cm - height: 38.27 cm - weight: 3.9 kg
Sustainability Information
- ENERGY STAR Certified
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
