LG Electronics MP58VQ 27" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: C0MMWS00 Mfr#: 27MP58VQ
The LG IPS monitor ensures an awesome picture quality, that provides clear images and vivid colors from any angle for your viewing pleasure. It combines the smoothness and solidness in the curved structure. The beauty of the stand is like the icing on the cake.
  • Sleek Cut design
    The Sleek Cut design, the remarkable reduction of depth with body frame, adds sophisticated ambiance for your place.
  • Protect your eyes and view in comfort
    Did you know, that your eyes are affected by flickers on the monitor, while you may not have seen them? Over time, working, gaming and movie viewing can cause eye strain and fatigue. But, flicker-safe and reader mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
  • Immerse yourself in the game
    The black stabilizer allows you to have better visibility, even in dark scenes.
  • Customize your workspace for multitasking
    Screen split divides the display into multiple sections for different tasks by resizing the windows on the screen. Its advanced functions have expanded to combine 4 types of picture-in-picture (PIP) mode among different settings. With PIP mode you can work on the main screen, while watching a video in a smaller window floating on the screen.
  • Offers improved color vision to color weakness
    Color revision algorithms are used to help those with color weakness, who have difficulty distinguishing certain ranges of colors can view all the important content.
LG 27MP58VQ - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
High-gloss piano black
63.41 cm x 20.47 cm x 46.95 cm
4.3 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, TUV, cUL, EPA 6.0
Display Type
Energy Class
Class A
41 kWh
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
German, French, Italian, Portuguese, Polish, Finnish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
4:3 in Wide, SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, 6-axis colour adjustment, Color Cloning, Black Stabilizer, Sleek Cut Design, Color Weakness Mode
63.41 cm x 20.47 cm x 46.95 cm - with stand
4.3 kg
VGA , HDMI , DVI-D , Headphones
Mechanical
Tilt
Tilt Angle
-2/+15
Cable holder
1 x VGA cable , 1 x HDMI cable
Backlight Life
50,000 hours
MTBF
50,000 hour(s)
Input Voltage
28 W
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 63.41 cm - depth: 20.47 cm - height: 46.95 cm - weight: 4.3 kg , Without stand - width: 63.41 cm - depth: 9.11 cm - height: 38.27 cm - weight: 3.9 kg
Sustainability Information
ENERGY STAR Certified
C0MM C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
