This display features Flicker Safe and Reader Mode to help maximize visual comfort by protecting your eyes from harmful blue light and greatly reducing the flicker level.
Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
Protect your eyes and view in comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and greatly reducing the flicker level. -
Customize your workspace for multitasking
Screen Split divides the display into multiple sections for different tasks by resizing the windows on the screen. With the featured PIP Mode you can work on the main screen while watching a video in a smaller window floating on the screen. -
Offers improved color vision to color weakness
- LG 24M38H-B - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Class
- Class A
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 21 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- HDMI, VGA
- Voltage
- AC 120/230 V
- 55.62 cm x 18.67 cm x 41.51 cm
- 2.8 kg
- Plug and Play, DDC/CI
- Display Type
- Energy Class
- Class A
- 31 kWh
- Diagonal Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- OSD Languages
- Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- Picture Mode, SUPER Energy Saving Technology, Auto Resolution, Dual Smart Solution, 4-screen split, Multilingual On Screen Display
- 55.62 cm x 18.67 cm x 41.51 cm - with stand
- 2.8 kg
- VGA , HDMI , Headphones
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Input Voltage
- AC 120/230 V
- 21 W
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 55.62 cm - depth: 18.67 cm - height: 41.51 cm - weight: 2.8 kg , Without stand - width: 55.62 cm - depth: 5.68 cm - height: 34.4 cm - weight: 2.6 kg
