Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
Protect your eyes and view in comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero. -
Preset customized options with just a click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse. -
Customize your workspace for multitasking
- LG 20M38A - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.262 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1976)
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black, black hairline front and base, black high glossy stand
- 46.3 cm x 16.78 cm x 35.88 cm
- 2.2 kg
- Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, EPA 6.0
- Display Type
- Diagonal Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.262 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% (CIE 1976)
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- Picture Mode, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, Smart Energy Saving technology, Intelligent Auto, Color Weakness Mode
- 46.3 cm x 16.78 cm x 35.88 cm - with stand
- 2.2 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 75 x 75 mm
- Key lock
- Included Accessories
- Stand
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 46.3 cm - depth: 16.78 cm - height: 35.88 cm - weight: 2.2 kg , Without stand - width: 46.3 cm - depth: 5.74 cm - height: 28.65 cm - weight: 2 kg
