The display switches signals from first player to second player as well as signals from an external player to internal memory in case of a player’s failure
LG’s advanced self-diagnosis function checks the screen status with an optional pixel sensor and supports the SNMP standards for compatibility with 3rd party solutions.
Compatible with open pluggable specification (OPS), users have the flexibility to choose the appropriate media player.
A Wi-Fi dongle can be connected to the LS75A for easy installation and simple management.
Enhanced fail over
The display switches signals from first player to second player as well as signals from an external player to internal memory in case of a player’s failure -
Remote control via RS232C & network
LG’s advanced self-diagnosis function checks the screen status with an optional pixel sensor and supports the SNMP standards for compatibility with 3rd party solutions. -
OPS compatibility
Compatible with open pluggable specification (OPS), users have the flexibility to choose the appropriate media player. -
Wi-Fi support
- LG 55LS75A 55" Class (54.64" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Diagonal Size
- 54.64"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 720p, 1080i, 1080p
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- Speakers not included
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 140 Watt
- Dimensions (WxDxH) - without stand
- 123 cm x 3.2 cm x 70.1 cm
- 20.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 140 Watt
- Diagonal Class
- 55"
- Diagonal Size
- 54.64"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, DisplayPort
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 123 cm
- 3.2 cm
- 70.1 cm
- 20.7 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 1300:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 700 cd/m²
- Response Time
- 8 ms
- Backlight Life
- 50,000 hour(s)
- Certified for 24/7 Continuous Operation, compatible with SuperSign Software
Video Wall
- 225
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
Media Player
- USB Port
Remote Control
- Remote control
Audio System
- Speaker System
- External Speakers Amplifier Power (Total)
- 20 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- LAN , DisplayPort input , 2 x HDMI input , DVI-D input , Serial input , Audio line-in , Serial output , DisplayPort output , Speakers output
- FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 123 cm x 3.2 cm x 70.1 cm x 20.7 kg , Panel with stand - 123 cm x 29.8 cm x 77.6 cm x 22.1 kg , Panel with stand and speakers - 123 cm x 29.8 cm x 77.6 cm x 22.9 kg
- Width (Shipping)
- 133 cm
- Depth (Shipping)
- 17.4 cm
- Height (Shipping)
- 81 cm
- Weight (Shipping)
- 25.2 kg
- 0 °C
- 40 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
