Synchronize your multi-room speakers together to play the same song in every room or to suit all your family's music tastes, stream different tracks around the house.
As soon as you arrive home, LG MUSIC flow syncs with your devices via Wi-Fi so you can continue listening to your music seamlessly. Just tap an NFC compatible device against your MUSIC flow speakers to add them to the network for music that follows you around the home.
Music that flows around your home
Synchronize your multi-room speakers together to play the same song in every room or to suit all your family's music tastes, stream different tracks around the house. -
Sync automatically with all your devices
As soon as you arrive home, LG MUSIC flow syncs with your devices via Wi-Fi so you can continue listening to your music seamlessly. Just tap an NFC compatible device against your MUSIC flow speakers to add them to the network for music that follows you around the home. -
High definition sound
Listen to your music in high definition sound quality and play high quality lossless compressed files. -
Music flow player
The LG MUSIC flow Player is more than just a remote letting you play music from multiple devices and connect to your favorite streaming sites. Whenever you're at home or not, LG MUSIC flow Player gives you complete control over what you want to play. -
Home cinema mode
Simply add an LG MUSIC flow soundbar to your network and synchronize it with your LG MUSIC flow speakers to enjoy a home cinema experience. -
Seamless streaming
LG MUSIC flow provides a stable connection, delivered via Wi-Fi technology without the risk of interruptions.
- LG MUSIC flow H7 - speaker - wireless
- Product Type
- Speaker
- Speaker Type
- Active
- Continuous Power
- 70 Watt
- Amplifier
- Integrated
- Bluetooth, Wi-Fi, NFC
- DLNA
- 37 cm x 11 cm x 23.2 cm
- 4.1 kg
- Product Type
- Speaker
Speaker System
- Speaker Type
- Active
- Continuous Power
- 70 Watt
- Amplifier
- Integrated
- Bluetooth, Wi-Fi, Near Field Communication (NFC)
- DLNA
- Controls
- Power on/off, volume
- Connector Type
- LAN , Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor
- Power Source
- AC power adapter
- 37 cm
- 11 cm
- 23.2 cm
- 4.1 kg
