LG Electronics G4 SIM Free Android 32GB - Titan Grey
Quicklinx: B9Q0WS00 Mfr#: LGH815.AGBRVK
  • microSDHC
  • Android
In creating the G4, LG designers took inspiration from everywhere to create an ergonomic, gently contoured device crafted from timeless materials. As a result, the smartphone has never looked - or felt - so good.
Photographers and amateurs have something new in common: the G4. With its f/1.8 low-light lens, Manual Mode, Optical Image Stabilization, Laser Autofocus, and high-res image sensors, the smartphone is finally getting a pro-grade upgrade.
The 5.5" IPS Quantum display on the G4 is brighter, more colorful, and has more contrast than ever before. It's their boldest and most brilliant yet, kind of like the G4 itself.
  • Forward-thinking design with a classic touch
  • See the bigger picture, and capture it
  • Look on the brilliant side
  • The power you need, plus a little more
    With improved processing and battery management, the all-new G4 is the perfect balance of speed and endurance.
LG G4 H815 - metallic grey - 4G smartphone - 32 GB - GSM
4G smartphone
Manufacturer Model Number
H815
Display
LCD display - 2560 x 1440 pixels - 5.5" - 538 ppi - IPS
Qualcomm Snapdragon 808 1.8 GHz (6-core) - 64-bit
RAM 3 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 2 TB
Operating System
Android 5.1 (Lollipop)
Main Camera
16 Megapixel - f/1.8 - focus: automatic, manual laser auto focus: - laser focus
Front Camera
8 Megapixel
Service Provider
Not specified
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Metallic grey
76.1 mm x 9.8 mm x 148.9 mm
155 g
0.62 W/kg
SAR Category (Belgium)
B
Smartphone
H815
Touch
76.1 mm
9.8 mm
148.9 mm
155 g
Body Colour
Metallic grey
Body Material
Leather coating
SAR Value
0.62 W/kg
B
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Navigation
A-GPS
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.1
Phone Features
Phone Functions
Speakerphone, call timer, conference call, vibrating alert
Additional Features
Curved display, Smart Notice
Media Player
Supported Digital Audio Standards
MP3
Clock Speed
1.8 GHz
Processor Core Qty
6-core
64-bit Architecture
RAM
3 GB
Internal Memory Capacity
32 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 2 TB
Front Camera
Sensor Resolution
8 Megapixel
Main Camera
Sensor Resolution
16 Megapixel
Lens Aperture
F/1.8
Focus Adjustment
Automatic, manual
Laser Auto Focus
Camera Modes
Selfie mode, Gesture Shot, Expert Mode
Face Detection
Face detection
Light Source
LED light
Touch & Shoot, Optical Image Stabiliser plus (OIS+)
Display
LCD display
IPS
Diagonal Size
5.5"
Display Resolution
2560 x 1440 pixels
Display Format
QHD
Pixel Density
538 ppi
Enhancement Technology
Quantum dot display technology
Connector Type
Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
3000 mAh
Wireless Charging
Power adapter
