In creating the G4, LG designers took inspiration from everywhere to create an ergonomic, gently contoured device crafted from timeless materials. As a result, the smartphone has never looked - or felt - so good.
Photographers and amateurs have something new in common: the G4. With its f/1.8 low-light lens, Manual Mode, Optical Image Stabilization, Laser Autofocus, and high-res image sensors, the smartphone is finally getting a pro-grade upgrade.
The 5.5" IPS Quantum display on the G4 is brighter, more colorful, and has more contrast than ever before. It's their boldest and most brilliant yet, kind of like the G4 itself.
Forward-thinking design with a classic touch
In creating the G4, LG designers took inspiration from everywhere to create an ergonomic, gently contoured device crafted from timeless materials. As a result, the smartphone has never looked - or felt - so good. -
See the bigger picture, and capture it
Photographers and amateurs have something new in common: the G4. With its f/1.8 low-light lens, Manual Mode, Optical Image Stabilization, Laser Autofocus, and high-res image sensors, the smartphone is finally getting a pro-grade upgrade. -
Look on the brilliant side
The 5.5" IPS Quantum display on the G4 is brighter, more colorful, and has more contrast than ever before. It's their boldest and most brilliant yet, kind of like the G4 itself. -
The power you need, plus a little more
With improved processing and battery management, the all-new G4 is the perfect balance of speed and endurance.
- LG G4 H815 - metallic grey - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- H815
- Display
- LCD display - 2560 x 1440 pixels - 5.5" - 538 ppi - IPS
- Processor
- Qualcomm Snapdragon 808 1.8 GHz (6-core) - 64-bit
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 2 TB
- Operating System
- Android 5.1 (Lollipop)
- Main Camera
- 16 Megapixel - f/1.8 - focus: automatic, manual laser auto focus: - laser focus
- Front Camera
- 8 Megapixel
- Service Provider
- Not specified
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Metallic grey
- 76.1 mm x 9.8 mm x 148.9 mm
- 155 g
- Specific Absorption Rate (SAR)
- 0.62 W/kg
- SAR Category (Belgium)
- B
- Product Type
- Smartphone
- H815
- Form Factor
- Touch
- 76.1 mm
- 9.8 mm
- 148.9 mm
- 155 g
- Body Colour
- Metallic grey
- Body Material
- Leather coating
- SAR Value
- 0.62 W/kg
- B
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Navigation
- A-GPS
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.1
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, vibrating alert
- Additional Features
- Curved display, Smart Notice
Media Player
- Supported Digital Audio Standards
- MP3
- Clock Speed
- 1.8 GHz
- Processor Core Qty
- 6-core
- 64-bit Architecture
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 2 TB
Front Camera
- Sensor Resolution
- 8 Megapixel
Main Camera
- Sensor Resolution
- 16 Megapixel
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic, manual
- Laser Auto Focus
- Camera Modes
- Selfie mode, Gesture Shot, Expert Mode
- Face Detection
- Face detection
- Light Source
- LED light
- Touch & Shoot, Optical Image Stabiliser plus (OIS+)
Display
- LCD display
- Technology
- IPS
- Diagonal Size
- 5.5"
- Display Resolution
- Display Format
- QHD
- Pixel Density
- 538 ppi
- Enhancement Technology
- Quantum dot display technology
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Capacity
- 3000 mAh
- Wireless Charging
- Included Accessories
- Power adapter
