G3's stunning Quad HD display supports an astounding 538ppi, commonly used to print high-quality gallery artbooks. This delivers vibrant colors and ultra-sharp images in 2,560 x 1,440pixels, so you won't ever notice any pixel. Plus, with its near zero bezel edge to edge 5.5 inch screen, you can experience the exquisite picture quality of Quad HD right in your palm.
A classic, metallic body that is light-weight, adds comfort and portability. Intuitively refined Rear Key and Floating Arc Design make the sides much thinner, allowing easy one-hand control.
The finest visibility, Quad HD display
G3's stunning Quad HD display supports an astounding 538ppi, commonly used to print high-quality gallery artbooks. This delivers vibrant colors and ultra-sharp images in 2,560 x 1,440pixels, so you won't ever notice any pixel. Plus, with its near zero bezel edge to edge 5.5 inch screen, you can experience the exquisite picture quality of Quad HD right in your palm. -
Lightweight metallic design
A classic, metallic body that is light-weight, adds comfort and portability. Intuitively refined Rear Key and Floating Arc Design make the sides much thinner, allowing easy one-hand control. -
Software diet
The number of pre-installed apps has been reduced by merging similar apps into one. Additionally, pre-installed apps can be deleted if you want, freeing up more space if you wish. -
Intuitive and aesthetic graphic user interface
Remove unnecessary visual elements to improve user interface. Each function features a different color, so you can spot what you need at a glance. -
Smart Notice, before you ask
Smart Notice suggests what you need, even before you need it. Predictive recommendations are based on the status of your phone, behavior, and location. -
1-watt speaker with boost amp
Plays deep, low and clear, high pitched sounds without the use of additional speakers. -
Knock code, the most secure, simple and fun way to unlock your phone
Wake and unlock your phone all at once using a customised knocking pattern of two to eight taps. With over 80,000 possible combinations, it adds a new level of fun! -
Smart keyboard
LG G3's smart keyboard makes typing easier and faster and helps reduce typing mistakes. -
LG Quick Circle case
The Quick Circle window displays the six apps you use the most, making it easier to access them. Plus, the soft ambient glow around the circle adds that extra hint of style and sophistication. -
Hassle-free wireless charging
G3's wireless charging frees you from plugging in, and the battery density has been increased to 3,000mAh to give you longer lasting usage time. Also, the battery is removable so you can always keep a spare battery on standby.
- LG G3 D855 - black - 4G smartphone - 16 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- D855
- Display
- LCD display - 2560 x 1440 pixels - 5.5" - 538 ppi - IPS
- Processor
- Qualcomm Snapdragon 2.46 GHz (quad-core)
- Memory
- RAM 2 GB / 16 GB
- Supported Memory Card
- microSDXC slot - up to 128 GB
- Operating System
- Android 4.4.2 (KitKat)
- Main Camera
- 13 Megapixel - BSI-CMOS focus: automatic
- Service Provider
- Not specified
- Wireless Interface
- NFC, Bluetooth, Wi-Fi 5
- Messaging Services
- SMS, MMS
- Black
- 74.6 mm x 8.9 mm x 146.3 mm
- 149 g
- Specific Absorption Rate (SAR)
- 0.291 W/kg (head) , 0.269 W/kg (body)
- SAR Category (Belgium)
- A
- Product Type
- Smartphone
- D855
- Form Factor
- Touch
- 74.6 mm
- 8.9 mm
- 146.3 mm
- 149 g
- Body Colour
- Black
- Body Material
- Polished metallic
- SAR Value
- 0.269 W/kg (body), 0.291 W/kg (head)
- A
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Navigation
- A-GPS, GLONASS
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- NFC, Bluetooth 4.0, IEEE 802.11a/b/g/n/ac
- Communication Features
- Mobile Email client, Internet browser
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, vibrating alert
- Sensors
- Gesture
- Additional Features
- Guest Mode function, TV-out via SlimPort, Circuit Switch FallBack support (CSFB), MIMO technology, Knock Code function, Smart Notice, Smart Keyboard, Smart Security
Organiser
- Personal Information Management
- Calendar, synchronization with PC, calculator, reminder, alarm clock
Media Player
- Supported Digital Audio Standards
- MP3, apt-X
- Clock Speed
- 2.46 GHz
- Processor Core Qty
- Quad-core
- RAM
- 2 GB
- Internal Memory Capacity
- 16 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 128 GB
Main Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Type
- BSI-CMOS
- Focus Adjustment
- Automatic
- Camera Modes
- Selfie mode
- Light Source
- Dual LED flash
- Touch & Shoot, Optical Image Stabiliser plus (OIS+)
Display
- LCD display
- Technology
- IPS
- Diagonal Size
- 5.5"
- Display Resolution
- Display Format
- QHD
- Pixel Density
- 538 ppi
- Capacity
- 3000 mAh
- Wireless Charging
- Included Accessories
- Power adapter
