Ultra HD 4K resolution is four times that of Full HD, resulting in brilliant clarity and vivid details that amaze, even up close. Enjoy a higher standard of definition. Combining the advancements in color packages and light filtering technology, LG delivers additional color. The result is hidden beauty comes alive as you explore color hues and shades you never knew existed. LG's Smart TV webOS platform revolutionizes the way you watch and experience entertainment on your Ultra HD TV. Free from the complexities of advanced technology, you can enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together some of catch-up TV, movies, sport and music services.
Ultra HD 4K resolution is four times that of Full HD, resulting in brilliant clarity and vivid details that amaze, even up close. Enjoy a higher standard of definition. -
ColorPrime
Combining the advancements in color packages and light filtering technology, LG delivers additional color. The result is hidden beauty comes alive as you explore color hues and shades you never knew existed. -
WebOS
LG's Smart TV webOS platform revolutionizes the way you watch and experience entertainment on your Ultra HD TV. Free from the complexities of advanced technology, you can enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together some of catch-up TV, movies, sport and music services. Whatever you wish to watch, find, launch, or play, you can do it easily with webOS, the efficient and user-friendly Smart TV designed with you in mind. -
Ultra HD 4K streaming
Thanks to LG's intuitive Smart TV webOS platform you can enjoy Ultra HD 4K content from some of the leading service providers. Say hello to advanced technology, today. -
4K Upscaler
The 4K Upscaler converts lower resolution entertainment to near 4K quality using a unique 6-step image processing technology. So whether it's broadcasts, movies, sports or more, you can enjoy it in incredible detail. -
ULTRA Surround
Complete your viewing experience with ULTRA Surround. This multi-channel sound effect will immerse you with realistic audio yet from seven virtual channels. -
Magic Remote Control
Access a growing world of entertainment on your LG Smart TV with the intuitive Magic Remote using point, scroll, gesture or voice commands. -
Plug-and-Play
With mulitple inputs you can simply plug in your HDMI cable or USB and play out your entertainment, games or digital devices through your TV.
- LG 58UF830V 58" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 58"
- Platform
- webOS 2.0
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 1600 Hz Picture Mastering Index
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Speaker System
- 2 speakers
- Sound Effects
- ULTRA Surround
- USB
- 3 ports
- Included Accessories
- Universal remote
- Energy Class
- Class A+
- 89 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions (WxDxH) - without stand
- 129.8 cm x 5.42 cm x 77 cm
- 22.8 kg
- Product Type
- Energy Class
- Class A+
- 89 Watt
- Diagonal Class
- 58"
- Platform
- webOS 2.0
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 3 ports
- HDCP Compatible
- Dimensions
- Without stand
- 129.8 cm
- 5.42 cm
- 77 cm
- 22.8 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Edge-lit LED
- 4K Upscaling
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 300 mm
TV Tuner
- Conditional Access
- Common Interface (CI) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Universal remote
- LG Magic Motion Remote Control
Audio System
- Surround Mode
- Sound Effects
- ULTRA Surround
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, built-in Dolby Digital decoder
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
- DLNA
- Connector Type
- Composite video / component video input - rear , Audio line-in - rear , 3 x HDMI - side , USB 3.0 - side , 2 x USB 2.0 - side , Digital audio output (optical) - rear , LAN - rear , SCART - rear , Headphones - rear
- Power Device
- Power supply
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 129.8 cm x 5.42 cm x 77 cm x 22.8 kg , Panel with stand - 129.8 cm x 26.3 cm x 81.5 cm
- Width (Shipping)
- 139.6 cm
- Depth (Shipping)
- 15.2 cm
- Height (Shipping)
- 85.7 cm
- Weight (Shipping)
- 28 kg
