Ultra HD Large screen delivers immersive viewing experience. Ultra HD delivers immersive viewing experience by 4 times higher definition picture quality than FHD. 98" real size displays deliver seamless contents so that could be alternative solution of 2x2 video wall at flagship store.
It works perfectly even if it is pulled by the gravity on portrait mode thanks to its advanced panel technology. The enhanced fail over function enables to display contents in internal memory without a dead spot even when the conditions of all external inputs are not working.
Ultra HD Large screen delivers immersive viewing experience. Ultra HD delivers immersive viewing experience by 4 times higher definition picture quality than FHD. 98” real size displays deliver seamless contents so that could be alternative solution of 2x2 video wall at flagship store. -
Ultra HD up-scaling
Up-scaling and Super Resolution technology enhance FHD contents quality to near-UHD quality. -
HEVC contents playback
It supports HEVC-based contents which have double data compression ratio than H.264 so network traffic can be reduced half. -
Gravity defect free on portrait mode
It works perfectly even if it is pulled by the gravity on portrait mode thanks to its advanced panel technology. -
Smart platform
High Performance embedded SoC can play various contents with reduced TCO and webOS Platform based SDK and API support simple customization. High Performance SoC delivers powerful embedded SoC to play various contents and additional 8GB internal storage and reduces TCO by decreasing the need for an external media player. -
Simple customization
It offers a customized apps for customer using LGE’s SDK and API. -
Enhanced fail over
- LG 98LS95A 98" Class (97.52" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 98"
- Diagonal Size
- 97.52"
- Commercial Use
- Yes - digital signage
- Platform
- webOS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Black level correction
- Speaker System
- 2 speakers
- DVR
- Flash - 8 GB
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- USB
- 3 ports
- Included Accessories
- Remote control, IR receiver, Wi-Fi module
- Voltage
- AC 120/230 V (50/60 Hz)
- 510 Watt
- Power Consumption Stand by
- 2 Watt
- Dimensions (WxDxH) - without stand
- 219.2 cm x 6.9 cm x 124.7 cm
- 88 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 510 Watt
- Diagonal Class
- 98"
- Diagonal Size
- 97.52"
- Commercial Use
- Platform
- webOS
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor, auto brightness sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, DisplayPort
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Picture mode
- Dimensions
- Without stand
- 219.2 cm
- 6.9 cm
- 124.7 cm
- 88 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct-lit LED
- Coating
- Anti-reflection
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Colour Temperature Control
- Yes (Warm/Medium/Cool)
- Gamma correction, Dynamic Contrast, Digital Noise Reduction (DNR), digital daisy chain, Dynamic Color Enhancer, key lock, 4K Upscaling, Dynamic Clear White, Input Labelling, compatible with SuperSign Software, Enhanced Fail Over
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 800 x 400 mm
DVR
- DVR
- Flash - 8 GB
Media Player
- Supported Video Formats
- HEVC
- USB Port
- USB Ports Qty
- 3
- Configuration
- Dual-Core ( 1 GHz ) - 1.25 GB DDR3 - 8 GB
- 8 GB
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- On/off switch, Clear Voice II technology
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- 2 x HDMI input , DVI-D input , DisplayPort input , DisplayPort output , Audio input , Serial input , Serial output , LAN , Remote control/ambient sensor input , 2 x USB 2.0 , USB 3.0 , SPDIF output
- IR receiver, Wi-Fi module
- Cables Included
- DisplayPort cable , HDMI cable , Serial cable , Audio adaptor
- FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 2 Watt
- Power Consumption Sleep
- 0.5 Watt
- Smart energy saving
- Width (Shipping)
- 234.2 cm
- Depth (Shipping)
- 40.2 cm
- Height (Shipping)
- 138.9 cm
- Weight (Shipping)
- 123 kg
- 0 °C
- 40 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
