LG's touch technology provides smooth and accurate 10 point multi-touch interaction & gestures with precision for your interactive needs. When touching the screen, it is possible to express your writing or drawing with 'No Ghosting' for clean & seamless navigation.
Multi-touch display
LG's touch technology provides smooth and accurate 10 point multi-touch interaction & gestures with precision for your interactive needs. -
84" the world's largest
The only ultra HD-based touch screen displaying is clear & sharp resolution contents in real life picture quality. -
Ghost free multi-touch
When touching the screen, it is possible to express your writing or drawing with "No Ghosting" for clean & seamless navigation.
- LG 84WT70 84" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 84"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 350 Watt
- Dimensions (WxDxH) - without stand
- 195.1 cm x 11.2 cm x 113.7 cm
- 102.6 kg
- Product Type
- 350 Watt
- Diagonal Class
- 84"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor, auto brightness sensor
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Landscape mode
- Dimensions
- Without stand
- 195.1 cm
- 11.2 cm
- 113.7 cm
- 102.6 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1400:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 12 ms
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Audio Controls
- Balance
- External Speakers Amplifier Power (Total)
- 20 Watt
- On/off switch, Clear Voice II technology
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- VGA input , 2 x HDMI input , 2 x USB 2.0 , Audio line-out , LAN , Serial output , DVI-D input , Audio line-in , DisplayPort input , Composite video input , Serial input , DVI-D output , VGA output
- FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC, ERP
- Power Device
- Power supply
- Input Voltage
- Smart energy saving
- Width (Shipping)
- 205 cm
- Depth (Shipping)
- 33 cm
- Height (Shipping)
- 126.1 cm
- Weight (Shipping)
- 118 kg
- 0 °C
- 40 °C
- 10 - 80%
