The sheer size of the screen, equal to four 42-inch class displays, gives you a breathtaking viewing experience. The picture is so big and immersive, it's as if you're in the scene and part of the action.
Boasting a pixel resolution 4x higher than Full HD (1080p), its detail is so vivid and crisp, even when viewed from a close distance.
No blackening defect
Display has a built-in temperature control that adjusts to light and heat eliminating dark or blackened areas. -
True wide viewing
Color changes and distortion are eliminated from any viewing angle. -
Panel stability
Minimized image distortion when external pressure is applied. -
84" edge led large screen
The sheer size of the screen, equal to four 42-inch class displays, gives you a breathtaking viewing experience. The picture is so big and immersive, it's as if you're in the scene and part of the action. -
Super high resolution 3,840 x 2,160 (ultra HD)
- LG 84WS70MS 84" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 84"
- Commercial Use
- Yes - digital signage
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Max Number of Screens
- 25
- Video Interface
- HDMI
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- AH-IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (47 - 63 Hz)
- 350 Watt
- Power Consumption Stand by
- 1 Watt
- Dimensions (WxDxH) - without stand
- 192.3 cm x 10.1 cm x 110.94 cm
- 72.9 kg
- 3-year warranty
- Product Type
- 350 Watt
- Diagonal Class
- 84"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 192.3 cm
- 10.1 cm
- 110.94 cm
- 72.9 kg
Display
- LCD Display Technology
- AH-IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Coating
- 3H Hard
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1400:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.484 x 0.484mm
- Response Time
- 12 ms
Video Wall
- 25
Media Player
- Supported Video Formats
- DivX
- Supported Audio Formats
- MP3
- Supported Pictures Formats
- JPG
- USB Port
Remote Control
- Remote control
- Connector Type
- VGA input , Serial , HDMI input , USB , LAN , DisplayPort input , DVI-D input
- Cables Included
- VGA cable
- FCC Class B certified, UL, TUV, VCCI, C-Tick, KCC
- Power Device
- Power supply
- Input Voltage
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years - pick-up and return
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
