The 84WS70BS provides immersive wide viewing with high quality. By realizing the LED display with the large screen size, super high resolution becomes possible to offer high realistic sensation and impressiveness. Local Dimming technology allows brightness to be controlled in block units. This ensures brightness and clarity providing high picture quality. As a bonus, power consumption is reduced. Screen brightness is automatically adjusted by its surrounding illumination level. Making your signage look even slimmer and helps you maintain the system far more conveniently.
84" edge LED large screen
Providing immersive wide viewing with high quality. -
Super high resolution 3,840 x 2,160 (Ultra HD)
By realizing the LED display with the large screen size, super high resolution becomes possible to offer high realistic sensation and impressiveness. -
Clear and vivid picture
Local Dimming technology allows brightness to be controlled in block units. This ensures brightness and clarity providing high picture quality. As a bonus, power consumption is reduced. -
Auto brightness sensor
Screen brightness is automatically adjusted by its surrounding illumination level. -
Hybrid type media player built-in ready
- LG 84WS70BS 84" LED-backlit LCD TV - 4K - for digital signage
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 84"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 350 Watt
- Dimensions (WxDxH) - without stand
- 192.3 cm x 5.1 cm x 110.9 cm
- 72.8 kg
- Product Type
- 350 Watt
- Diagonal Class
- 84"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 192.3 cm
- 5.1 cm
- 110.9 cm
- 72.8 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1400:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Compatible with SuperSign Software
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance
- External Speakers Amplifier Power (Total)
- 20 Watt
- On/off switch, Clear Voice II technology
- Connector Type
- VGA input , Serial input , 2 x HDMI input , 2 x USB , VGA output , LAN , Serial output , DVI-D input , DVI-D output , Speakers output , DisplayPort input , Composite video input , Audio output , Audio input
- Cables Included
- VGA cable
- FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 Watt
- Smart energy saving
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
