LG Electronics 84WS70B 84" 3840x2160 4K LED Large Format Display
Quicklinx: 9X85WS00 Mfr#: 84WS70B
LG 84WS70B are LED large screens which provides immersive wide viewing with high quality.
  • 84" edge LED large screen
    Providing immersive wide viewing with high quality.
  • Hybrid type media player built-in ready
    Making your signage look even slimmer and helps you maintain the system far more conveniently.
  • Media player integrated solution
    The solution integrated with media player foregoes the need for additional media players and allows you to cut down expenses.
LG 84WS70B WS70 Series - 84" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
84"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
Edge-lit LED local dimming
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage
USB
2 ports
Remote control
Voltage
350 Watt
192.3 cm x 5.1 cm x 110.9 cm
72.9 kg
350 Watt
Diagonal Class
84"
Commercial Use
Series
WS70 Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, auto brightness sensor
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Timer Functions
Sleep, wake
Dimensions
Without stand
192.3 cm
5.1 cm
110.9 cm
72.9 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Edge-lit LED - local dimming
Coating
Anti-glare
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Backlight Life
50,000 hour(s)
Commercial Features
Digital signage
Dynamic Contrast, Eye Care, Super Resolution Technology (SRT), MPEG Noise Reduction, Dynamic Color Enhancer, key lock, Dynamic Clear White, Input Labelling, compatible with SuperSign Software
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Audio Controls
Sound mode, balance
External Speakers Amplifier Power (Total)
20 Watt
On/off switch, Clear Voice II technology
Connector Type
VGA input , Serial input , 2 x HDMI input , 2 x USB , VGA output , LAN , Serial output , DVI-D input , DVI-D output , Speakers output , DisplayPort input , Composite video input , Audio output , Audio input
VGA cable
FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC
Power supply
Input Voltage
Power Consumption Sleep
0.5 Watt
Auto On/Off
Smart energy saving
Width (Shipping)
203.4 cm
Depth (Shipping)
31.4 cm
Height (Shipping)
121.3 cm
Weight (Shipping)
87.2 kg
10 - 80%
