LG Electronics 65UH5C 65" Black Large Format Display
Quicklinx: CYJVWS00 Mfr#: 65UH5C
Ultra HD Resolution (3,840 x 2,160)
Ultra HD Large screen delivers immersive viewing experience by 4 times higher definition picture quality than FHD.
High Efficiency Video Coding
Supports HEVC-based content which has the double data compression ratio than the H.264, so network traffic can be reduced by half.
Mirroring
Content sharing is more convenient on a Wi-Fi network.
Soft AP
The UH5C with Soft AP software can operate as a wireless access point for mobile devices.
Cost Effectiveness
Low Power Consumption Using The M+ Panel. The M+ panel offers excellent energy efficiency and cost savings and decreases power consumption by approx. 31 compared to conventional RGB panels.
Quad Core SoC
The high-performance SoC can execute several tasks at the same time and provides smooth content playback.
webOS 3.0
The webOS 3.0 platform provides powerful and convenient creation tools, including app development materials.
Group Manager
Content can be created, distributed and controlled by a signage without a dedicated PC or server.
PBP (Picture-By-Picture) / PIP (Picture-In-Picture)
PBP (Picture-By-Picture) and PIP (Picture- In-Picture) features enable you to compose various layouts for several digital devices.
IP Streaming Protocol
Various types of IP video streaming protocol are supported, such as RTSP/RTP, MMS, HLS and MPEG-2 TS.
Secure Communication Protocol
By supporting HTTPS* protocol, communication between server and signage is more secure.
Proxy Server
Web access speed and security can be improved by supporting Proxy Server (A server that acts as an intermediary for requests from clients seeking resources from other servers.)
  • Ultra HD resolution (3,840 x 2,160)
    Ultra HD large screen delivers immersive viewing experience by 4 times higher definition picture quality than FHD.
  • High efficiency video coding
  • Low power consumption using the M+ panel
    The M+ panel offers excellent energy efficiency and cost saving and decreases power consumption by approx. 31% compared to conventional RGB panels.
LG 65UH5C UH5C Series - 65" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Platform
webOS 3.0
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Max Number of Screens
225
Video Interface
HDMI
Wi-Fi, LAN
PC Interface
DVI, DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Sync Mode, Embedded Template, Contents Scheduling, SuperSign Elite-w lite compatible, SuperSign Elite-c compatible
Settings Cloning Capability
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
Supported Memory Cards
SD Memory Card
USB
Remote control, 2 batteries
Voltage
134 Watt
145.86 cm x 4.01 cm x 84.89 cm
26 kg
Environmental Standards
ENERGY STAR Qualified
134 Watt
Diagonal Class
65"
Commercial Use
Series
UH5C Series
Platform
webOS 3.0
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, auto brightness sensor
Video Interface
HDMI
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode, Natural Mode, Tile Mode
Dimensions
Without stand
145.86 cm
4.01 cm
84.89 cm
26 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
1000000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Backlight Life
50,000 hour(s)
Commercial Features
Certified for 24/7 Continuous Operation, Image Sticking Minimization (ISM), BEACON technology, picture in picture (no tuner), picture by picture (no tuner)
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Media Player
Supported Video Formats
HEVC
SD Memory Card
USB Port
USB Ports Qty
1
Configuration
8 GB
8 GB
Remote Control
Remote control
Network & Internet Multimedia
Wi-Fi, LAN
Wi-Fi Protocol
802.11n
Connector Type
Speakers output , Infrared (IrDA) , Pixel sensor , 2 x HDMI , LAN , Audio line-in , Audio line-out , DVI-D input , DisplayPort input , DisplayPort output , USB 3.0 , Serial input , Serial output
2 batteries
HDMI cable , Serial adapter
FCC Class A certified, UL, TUV, cUL, CB, EMC, KCC, KC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
WOL (Wake on LAN)
Width (Shipping)
156.1 cm
Depth (Shipping)
19 cm
Height (Shipping)
97.1 cm
Weight (Shipping)
32.5 kg
10 - 80%
