The panel featuring a direct-LED back light creates stylishly slim monitors designed to fit perfectly into narrow spaces in retail shops while ensuring high energy efficiency.
Slim design
The panel featuring a direct-LED back light creates stylishly slim monitors designed to fit perfectly into narrow spaces in retail shops while ensuring high energy efficiency. -
Remote control via RS232C and network
SuperSign embedded player with RJ45 interface allows easy content transfer and control via network. -
Cost-effective solution
No need for an additional media player. -
Orientation
Supports portrait/landscape mode.
- LG 65LS33A 65" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 720p, 1080i, 1080p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- Speakers not included
- USB
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 145 Watt
- Power Consumption (On mode)
- 145 W
- Power Consumption Stand by
- 0.4 Watt
- Energy Consumption per Year
- 212 kWh
- Dimensions (WxDxH) - without stand
- 146.2 cm x 5.8 cm x 84.3 cm
- 30.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class A
- 145 Watt
- 145 W
- 212 kWh
- Diagonal Class
- 65"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 146.2 cm
- 5.8 cm
- 84.3 cm
- 30.9 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Coating
- Anti-glare, 3H Hard
- Image Contrast Ratio
- 1400:1
- Dynamic Contrast Ratio
- 1500000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 9 ms
- Image Sticking Minimization (ISM), key lock
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1920 x 1080
Media Player
- USB Port
- USB Ports Qty
- 1
Audio System
- Speaker System
- External Speakers Amplifier Power (Total)
- 20 Watt
- Balance control, Clear Voice II technology
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- HDMI input , VGA input , Audio line-in , Serial input , Infrared (IrDA) , LAN , USB , Audio line-out , Serial output
- FCC Class A certified, UL, TUV, cUL, CB, EMC, KCC, KC, ERP
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.4 Watt
- 0.5 Watt
- Smart energy saving
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 146.2 cm x 5.8 cm x 84.3 cm x 30.9 kg , Panel with stand - 146.2 cm x 31.3 cm x 90.1 cm x 32.3 kg , Panel with stand and speakers - 146.2 cm x 31.3 cm x 90.1 cm x 33.1 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
