LG Electronics 65" Class Edge LED Commercial 1920 x 1080 HDTV
Quicklinx: CMYMWS00 Mfr#: 65LX341C
  • 1080p
The USB Cloning feature allows you to simply copy the TV settings onto all TVs using a USB stick, a process that is fully automated to save time without having to set each TV one by one. Welcome visitors with a warm greeting message that includes your business name and logo. Via the TV's RS-232C port, you can remotely control multiple TVs' power and volume settings simultaneously.
  • USB Cloning
  • Welcome screen
  • Multi IR
    Multi IR function eliminates the remote control signal interference between TVs in multiple dwelling rooms. This system will work using the same LG TV model.
  • RS-232C control
  • External speaker out
    Enhance the entertainment experience by adding an additional speaker, visitors to listen to and control the TV audio from anywhere in your business area, including restrooms.
  • USB 2.0
    You can play images and videos from and record TV programs to external storage devices.
LG Commercial Lite 65LX341C LX341C Series - 65" LED-backlit LCD TV - Full HD - for hotel / hospitality
LED-backlit LCD TV
Diagonal Class
65"
Commercial Use
Yes - hotel / hospitality
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, HDMI, SCART
HDMI Ports Qty
1 ports
LAN
PC Interface
VGA (HD-15), Mobile High-Definition Link (MHL)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Analogue TV Tuner
PAL, SECAM
Commercial Features
Screen welcome message, Remote Jack Pack, Lock Mode, Self Diagnostics, Guest Connectivity
Settings Cloning Capability
Speaker System
2 speakers
USB
Voltage
Energy Class
Class A++
145.6 Watt
Power Consumption (On mode)
80 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
117 kWh
146.1 cm x 29.4 cm x 89.9 cm
34 kg
LED-backlit LCD TV
Energy Class
Class A++
145.6 Watt
80 W
117 kWh
Diagonal Class
65"
Commercial Use
Series
LX341C Series
TV Tuner
TV Tuner Presence
Sensors
Intelligent sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
Modes
Hotel mode
Protection
Theft protection
Dimensions
With stand
146.1 cm
29.4 cm
89.9 cm
34 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Commercial Features
Eco Flower, One Channel Map, security lock slot (cable lock sold separately), RJP Compatible
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Analogue Video Input Signals
PAL, SECAM
Media Player
USB Port
USB Ports Qty
1
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
USB 2.0 - side , Headphones - side , Component video input - rear , Audio line-in - rear , Digital audio output (optical) - rear , VGA input - rear , Serial - rear , HDMI input - rear , LAN - rear , SCART - rear , Speakers output - rear
CB, RoHS, CEC, ERP, EU Ecolabel, CU-TR
Power supply
Input Voltage
0.3 Watt
Smart energy saving
