Hidden beauty comes alive. Combining the advanced improvements in color packages and light filtering technology ColorPrime Pro delivers a wider range of color spectrum. What you are watching is more vibrant and vivid with colors and shades, that you never knew existed.
Ultra Luminance
Expand your contrast range with Ultra Luminance. Enjoy brighter whites and darker blacks thanks to local dimming technology, which lifts the bright scenes to brilliant levels and the dark shadows to life. -
Wide viewing angle
Due to the nature of the display, the image on the screen maintains its integrity from any viewing angle. This allows you to enjoy dynamic, vibrant color from every seat in the room. -
3D color mapping
3D color mapping expresses life-like color through its 3D gamut mapping algorithm. It minimizes color distortion, allowing viewers to enjoy remarkably natural color. -
ULTRA Surround
ULTRA Surround sound enables a conventional two-channel speaker to function as a virtual seven-channel speaker. The addition of ULTRA Surround sound technology maximizes the 4K viewing experience. -
Local dimming
Local dimming adjusts the light by dividing the TV screen into multiple blocks. As the light is controlled independently in each block, details are clearly expressed in each area of the screen. This enables viewers to enjoy deeper blacks and clear, sharp images. -
Stylish design
Enjoy masterfully manufactured design. The material is wrapped around your television providing excellent construction. This sleek housing adds a modern touch to any living room.
- LG 58UH635V UH635V Series - 58" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 58"
- Platform
- webOS 3.0
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Technology
- HDR Pro
- Frame Rate & Enhancement Technology
- 1500 Hz Picture Mastering Index
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED local dimming
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Picture Enhancements
- Active Noise Reduction
- Sound Effects
- ULTRA Surround
- USB
- 2 ports
- Included Accessories
- Universal remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- Power Consumption (On mode)
- 87 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 127 kWh
- Dimensions (WxDxH) - without stand
- 129.8 cm x 5.42 cm x 77 cm
- 22.3 kg
- Product Type
- Energy Class
- Class A+
- 87 W
- 127 kWh
- Diagonal Class
- 58"
- Series
- UH635V Series
- Platform
- webOS 3.0
- HDR Capable
- HDR Technology
- HDR Pro
- Video Processor
- Quad-Core
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 3 ports
- Design
- Metallic Design
- Dimensions
- Without stand
- 129.8 cm
- 5.42 cm
- 77 cm
- 22.3 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED - local dimming
- Time-shift, Eco Flower, Quick Start, E-Manual, Dynamic Color Enhancer, 4K Upscaling, My Channel, Ultra Luminance, True Black, Magic Zoom, UHD Mastering Engine, Color Prime Pro, Magic Mobile Connection, 3D Color Mapping, Channel Advisor
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 300 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- MHEG
Video Features
- Teletext
- Teletext Memory
- 2000 pages
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Universal remote
Audio System
- Digital Audio Format
- Dolby Digital output, DTS digital output
- Surround Mode
- Sound Effects
- ULTRA Surround
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, built-in Dolby Digital decoder, Wireless Sound Sync, Clear Voice III technology
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Connect & Share
- Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
- Supported Consumer Electronics Control (CEC)
- Simplink
- Connector Type
- 3 x HDMI , 2 x USB , Composite video / component video input , LAN , Digital audio output (optical) , Serial input , Audio line-out / headphones
- CEC
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 129.8 cm x 5.42 cm x 77 cm x 22.3 kg , Panel with stand - 129.8 cm x 25.8 cm x 82.8 cm x 22.8 kg
- Width (Shipping)
- 143.4 cm
- Depth (Shipping)
- 25.8 cm
- Height (Shipping)
- 88 cm
- Weight (Shipping)
- 28.2 kg
