Making TV Simple Again
55" LG LED TV WITH FREEVIEW
- FULL HD RESOLUTION
- FREEVIEW
- IPS PANEL
- METALLIC DESIGN
- PLUG & PLAY
Virtual surround
Put yourself in the middle of the action with virtual surround that delivers an extended sound field. -
Metallic design
Enrich your living space with a modern metallic design that seamlessly blends in with your home's decor. -
Smart energy saving
The feature includes backlight control for adjusting brightness, a screen-off function that turns the picture off for playing audio only, and the Standby Mode Zero function which allows the TV to effectively hibernate, using zero electricity. -
Motion Eco Sensor
The Motion Eco Sensor is a brilliant technology that reduces power consumption by slightly adjusting the brightness of the screen relevant to the speed of the pictures.
- LG 55LF5610 55" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 55"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 300 Hz Picture Mastering Index
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T
- Speaker System
- 2 speakers
- Sound Effects
- Virtual Surround Mode
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- Power Consumption (On mode)
- 75 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 110 kWh
- Dimensions (WxDxH) - without stand
- 124.3 cm x 5.68 cm x 72.5 cm
- 17.3 kg
- Product Type
- Energy Class
- Class A+
- 75 W
- 110 kWh
- Diagonal Class
- 55"
- TV Tuner
- TV Tuner Presence
- Extended PVR
- Video Interface
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- Modes
- Expert mode, ISF mode
- Dimensions
- Without stand
- 124.3 cm
- 5.68 cm
- 72.5 cm
- 17.3 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Direct-lit LED
- Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- H.264
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, built-in Dolby Digital decoder, Clear Voice II technology, Sound Optimizer, Optical Sound Sync, Wireless Sound Sync, Private Sound Sync
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- USB 2.0 , 2 x HDMI input , Digital audio output (optical) , SCART , Composite video / component video input , Audio line-in , Headphones
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 124.3 cm x 5.68 cm x 72.5 cm x 17.3 kg , Panel with stand - 124.3 cm x 25.5 cm x 77.2 cm x 17.7 kg
- Width (Shipping)
- 133 cm
- Depth (Shipping)
- 17.4 cm
- Height (Shipping)
- 81 cm
- Weight (Shipping)
- 22.1 kg
