Product
LG Electronics 55" 1920x1080 12ms VGA DVI HDMI USB LED Large Format Display
Quicklinx: BRMWWS00 Mfr#: 55SE3B
Run messages on up to 50 display screens in the form of a billboard without any additional hardware. Advertisements, information and broadcast content can be arranged on the same screen to attract attention and deliver specific messaging to your customer base.
  • LG supersign
  • Conformal coating
    Conformal coating helps protect against water, dust and iron powder deposits which accumulate in harsh environments, saving on expensive installation and added enclosure costs.
  • USB content scheduling
    Play and schedule content using the USB connection without the need to connect to a server.
  • Detachable logo
    The detachable logo can be removed and repositioned to the desired setting. Perfect when using in Portrait Mode.
  • Wi-Fi support
  • Network management protocol
    Enables monitoring of TV's on the network by the head-end or a cloud server for maintenance and admin purposes. The instant on/warm mode feature allows the TV to communicate in a background mode while the TV is powered off and without disruption to the guest, providing the ability to deliver remote software updates from the head-end server and quick boot-up of embedded applications.
  • Aspect ratio sustainability
    Sustain the same resolution and picture quality while powering on/off by receiving Extended Display Identification Data through the IC switch.
LG 55SE3B-B 55"
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
USB
Remote Control
Standard remote
Voltage
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Display
Resolution
1920 x 1080
LED backlight
Media Player
USB Port
Remote Control
Standard remote
Power supply
Nominal Voltage
BRMW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BRMW C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.46
BRMW C2G 5m Select High Speed HDMI with Ethernet In Stock £21.58
BRMW C2G 10m Select High Speed HDMI with Ethernet In Stock £41.46
BRMW C2G 15m Select High Speed HDMI with Ethernet In Stock £56.17
BRMW C2G Pro HDMI to VGA Converter In Stock £51.78
BRMW C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
