LG Electronics 50" 50UH635V HDR Pro Freesat WebOs
Quicklinx: C3GZWS00 Mfr#: 50UH635V
Hidden beauty comes alive. Combining the advanced improvements in color packages and light filtering technology ColorPrime Pro delivers a wider range of color spectrum. What you are watching is more vibrant and vivid with colors and shades, that you never knew existed.
  • Ultra Luminance
    Expand your contrast range with Ultra Luminance. Enjoy brighter whites and darker blacks thanks to local dimming technology, which lifts the bright scenes to brilliant levels and the dark shadows to life.
  • Wide viewing angle
    Due to the nature of the display, the image on the screen maintains its integrity from any viewing angle. This allows you to enjoy dynamic, vibrant color from every seat in the room.
  • 3D color mapping
    3D color mapping expresses life-like color through its 3D gamut mapping algorithm. It minimizes color distortion, allowing viewers to enjoy remarkably natural color.
  • ULTRA Surround
    ULTRA Surround sound enables a conventional two-channel speaker to function as a virtual seven-channel speaker. The addition of ULTRA Surround sound technology maximizes the 4K viewing experience.
  • Local dimming
    Local dimming adjusts the light by dividing the TV screen into multiple blocks. As the light is controlled independently in each block, details are clearly expressed in each area of the screen. This enables viewers to enjoy deeper blacks and clear, sharp images.
  • Stylish design
    Enjoy masterfully manufactured design. The material is wrapped around your television providing excellent construction. This sleek housing adds a modern touch to any living room.
LG 50UH635V UH635V Series - 50" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
50"
Platform
webOS 3.0
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Technology
HDR Pro
Frame Rate & Enhancement Technology
1500 Hz Picture Mastering Index
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN, Bluetooth
IPS
LCD Backlight Technology
Edge-lit LED local dimming
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Picture Enhancements
Active Noise Reduction
Sound Effects
ULTRA Surround
USB
2 ports
Universal remote
Voltage
Energy Class
Class A+
Power Consumption (On mode)
66 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
96 kWh
112.2 cm x 5.33 cm x 66.4 cm
16.2 kg
Energy Class
Class A+
66 W
96 kWh
Diagonal Class
50"
Series
UH635V Series
Platform
webOS 3.0
HDR Capable
HDR Technology
HDR Pro
Video Processor
Quad-Core
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
Design
Metallic Design
Dimensions
Without stand
112.2 cm
5.33 cm
66.4 cm
16.2 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Edge-lit LED - local dimming
Time-shift, Eco Flower, Quick Start, E-Manual, Dynamic Color Enhancer, 4K Upscaling, My Channel, Ultra Luminance, True Black, Magic Zoom, UHD Mastering Engine, Color Prime Pro, Magic Mobile Connection, 3D Color Mapping, Channel Advisor
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
300 x 300 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
Video Features
Teletext
Teletext Memory
2000 pages
Media Player
USB Port
USB Ports Qty
2
Remote Control
Universal remote
Audio System
Digital Audio Format
Dolby Digital output, DTS digital output
Surround Mode
Sound Effects
ULTRA Surround
Output Power / Total
20 Watt
Built-in DTS decoder, built-in Dolby Digital decoder, Wireless Sound Sync, Clear Voice III technology
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11ac
Connect & Share
Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
Supported Consumer Electronics Control (CEC)
Simplink
Connector Type
3 x HDMI , 2 x USB , Composite video / component video input , LAN , Digital audio output (optical) , Serial input , Audio line-out / headphones
CEC
Power supply
Input Voltage
0.3 Watt
Dimensions & Weight Details
Panel without stand - 112.2 cm x 5.33 cm x 66.4 cm x 16.2 kg , Panel with stand - 112.2 cm x 23.1 cm x 71.7 cm x 16.5 kg
Width (Shipping)
119.7 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
79 cm
Weight (Shipping)
20 kg
