Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
Clear Voice enhances sound quality by separating voices from background noise to provide you with a clear and crisp listening experience. Focus on your content without distraction using Clear Voice.
Picture Wizard III
Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, colour, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
Virtual Surround
More channels, better sound. High quality software creates a surround sound effect producing virtual audio channels. Surround your senses with sound from all angles.
Picture Wizard III
Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment. -
Clear Voice
- LG 49LH5100 LH5100 Series - 49" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 49"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 300 Hz Picture Mastering Index
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 1 ports
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T
- Picture Enhancements
- Triple XD Engine, Picture Wizard III, Active Noise Reduction
- Speaker System
- 2 speakers
- Sound Effects
- Virtual Surround Mode
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A++
- Power Consumption (On mode)
- 39 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 57 kWh
- Dimensions (WxDxH) - without stand
- 110.8 cm x 8.15 cm x 65.7 cm
- 10.6 kg
- Product Type
- Energy Class
- Class A++
- 39 W
- 57 kWh
- Diagonal Class
- 49"
- Series
- LH5100 Series
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 1 ports
- Modes
- Game mode, Eco mode, Sports mode, Cinema mode
- Dimensions
- Without stand
- 110.8 cm
- 8.15 cm
- 65.7 cm
- 10.6 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T
- HDTV Tuner
- Digital TV Service
- FREEVIEW, MHEG
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Balance control, Clear Voice technology
Network & Internet Multimedia
- Supported Consumer Electronics Control (CEC)
- Simplink
- Connector Type
- HDMI , USB 2.0 , Composite video / component video input , SCART , Serial
- Batteries
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 110.8 cm x 8.15 cm x 65.7 cm x 10.6 kg , Panel with stand - 110.8 cm x 20.87 cm x 69.6 cm x 10.9 kg
- Width (Shipping)
- 119.7 cm
- Depth (Shipping)
- 15.2 cm
- Height (Shipping)
- 76 cm
- Weight (Shipping)
- 14.1 kg
