From LG's Next Generation 3D televisions, which offer the same depth, realism and entertainment as theater 3D, to Smart TVs with unlimited content, and LED televisions with exceptional image quality – there’s an LG TV for every room in your house.
Four times the resolution, four times the detail
ULTRA HD 4K resolution is four times that of Full HD, resulting in brilliant clarity and vivid details that amaze, even up close. Enjoy a new standard of definition. -
Scale new heights of resolution
The 4K Upscaler converts lower resolution entertainment to near 4K quality using a unique 6-step image processing technology. So whether it's broadcasts, movies, sports or more, you can now enjoy it in incredible detail. -
Making TV simple again
LG's award winning Smart TV webOS platform revolutionizes the way you watch and experience entertainment on your UHD TV. Free from the complexities of advanced technology, you can now enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together some of the best catch-up TV, movies, sport and music services. Whatever you wish to watch, find, launch, or play, you can do it easily with webOS, the efficient and user-friendly Smart TV designed with you in mind. -
ULTRA Surround
Complete your viewing experience with ULTRA Surround. This multi-channel sound effect will immerse you with the most realistic audio yet from seven virtual channels. -
Future proof your TV
HDMI 4K can transmit large amounts of data at once. This advanced technology supports 4K video with 60 frames per second, which is the standard for UHD broadcasting. Be ready for the UHD experience for HDMI 4K. -
Bigger screen, bigger experience
Now you can see more valuable experiences on bigger screen. Select various screen sizes for your various choices.
- LG 49UF770V 7 Ultra Series - 49" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 49"
- Platform
- webOS 2.0
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 24p Technology
- 24p Real Cinema
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight local dimming
- Internet Streaming Services
- Live Menu
- Picture Enhancements
- Dynamic Scanning
- Speaker System
- 2 speakers
- Sound Effects
- SMART SOUND, ULTRA Surround
- Stereo Reception System
- MTS
- USB
- 3 ports
- Included Accessories
- Remote control
- Energy Class
- Class A+
- Power Consumption (On mode)
- 67 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 98 kWh
- Dimensions (WxDxH) - without stand
- 110.4 cm x 5.67 cm x 64.5 cm
- 14 kg
- Product Type
- Energy Class
- Class A+
- 67 W
- 98 kWh
- Diagonal Class
- 49"
- Series
- 7 Ultra Series
- Platform
- webOS 2.0
- Video Processor
- Quad-Core
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 3 ports
- HDCP Compatible
- Modes
- Picture mode
- Dynamic Scanning
- Dimensions
- Without stand
- 110.4 cm
- 5.67 cm
- 64.5 cm
- 14 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 24p Technology
- 24p Real Cinema
- Widescreen Modes
- Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
- Time-shift, Micro Pixel Control, Dynamic Color Enhancer, Tru-Ultra HD Engine, TruBlack Control, Dynamic Clear White, Motion eye care, Ultra Luminance, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 300 mm
TV Tuner
- Conditional Access
- Common Interface (CI) slot
- MTS
- Secondary Audio Programme (SAP)
Digital TV Tuner
- HDTV Tuner
Media Player
- Supported Video Formats
- HEVC
- Supported Audio Formats
- MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS
- Supported Pictures Formats
- JPG, MPO, JPS
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
Audio System
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, built-in Dolby Digital decoder, Clear Voice II technology, Sound Optimizer, Wireless Sound Sync, Private Sound Sync, apt-X Encoder
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
- Live Menu
- Application Store
- LG App Store
- Connector Type
- USB 3.0 , 2 x USB 2.0 , 3 x HDMI input , Composite video input , Component video input , Audio line-in , SCART , Digital audio output (optical) , LAN , Headphones , Serial
- Power Device
- Power supply
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 110.4 cm x 5.67 cm x 64.5 cm x 14 kg , Panel with stand - 110.4 cm x 26.1 cm x 70.1 cm x 15.9 kg
- Width (Shipping)
- 119.7 cm
- Depth (Shipping)
- 15.2 cm
- Height (Shipping)
- 79 cm
- Weight (Shipping)
- 19.6 kg
