LG Electronics 47WV50BR 47" 1920x1080 12ms DVI-D DP LED LFD
Quicklinx: 9X8JWS00 Mfr#: 47WV50BR
  • 1080p
Display has a built-in temperature control that adjusts to light and heat eliminating dark or blackened areas.
WV Series provide Automatic Calibration solution which enables to save time and labor on installation by adjusting the white balance on video wall easily.
WV50 supports Full HD. You can enjoy super fine image from each and every displays composing video wall.
  • No blackening defect
  • True wide viewing
    Color changes and distortion are eliminated from any viewing angle.
  • Panel stability
    Minimized image distortion when external pressure is applied.
  • Slimmer bezel
    4.9mm, the slimmest bezels create powerful and impactful video walls.
  • Auto calibration
  • Auto higher resolution
LG 47WV50BR 47" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, IR receiver
Voltage
150 Watt
104.5 cm x 9 cm x 59 cm
18.5 kg
Environmental Standards
ENERGY STAR Qualified
150 Watt
Diagonal Class
47"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
104.5 cm
9 cm
59 cm
18.5 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
10 ms
Backlight Life
50,000 hour(s)
Image Sticking Minimization (ISM)
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Audio Controls
Sound mode, balance
Speaker System
2 speakers
Output Power / Total
20 Watt
Clear Voice II technology
Speakers
2 x main channel speaker - 10 Watt
Connector Type
HDMI input - rear , DVI-Digital - rear , DisplayPort input - rear , Component video input - rear , Composite video input - rear , Audio line-in - rear , RGB input - rear , Audio line-in - rear , Serial input - rear , Remote control - rear , USB - rear , DVI-D output - rear , RGB output - rear , Speakers output - rear , Serial output - rear
IR receiver
VGA cable
FCC Class B certified, UL, TUV, cUL, CB, KCC, KC, ERP
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
Smart energy saving
Width (Shipping)
118 cm
Depth (Shipping)
16.5 cm
Height (Shipping)
77 cm
Weight (Shipping)
23.5 kg
10 - 80%
