Display has a built-in temperature control that adjusts to light and heat eliminating dark or blackened areas.
WV Series provide Automatic Calibration solution which enables to save time and labor on installation by adjusting the white balance on video wall easily.
WV50 supports Full HD. You can enjoy super fine image from each and every displays composing video wall.
No blackening defect
Display has a built-in temperature control that adjusts to light and heat eliminating dark or blackened areas. -
True wide viewing
Color changes and distortion are eliminated from any viewing angle. -
Panel stability
Minimized image distortion when external pressure is applied. -
Slimmer bezel
4.9mm, the slimmest bezels create powerful and impactful video walls. -
Auto calibration
WV Series provide Automatic Calibration solution which enables to save time and labor on installation by adjusting the white balance on video wall easily. -
Auto higher resolution
- LG 47WV50BR 47" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 47"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 225
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, IR receiver
- Voltage
- AC 120/230 V (50/60 Hz)
- 150 Watt
- Dimensions (WxDxH) - without stand
- 104.5 cm x 9 cm x 59 cm
- 18.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 150 Watt
- Diagonal Class
- 47"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 104.5 cm
- 9 cm
- 59 cm
- 18.5 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 1400:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 10 ms
- Backlight Life
- 50,000 hour(s)
- Image Sticking Minimization (ISM)
Video Wall
- 225
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Clear Voice II technology
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- HDMI input - rear , DVI-Digital - rear , DisplayPort input - rear , Component video input - rear , Composite video input - rear , Audio line-in - rear , RGB input - rear , Audio line-in - rear , Serial input - rear , Remote control - rear , USB - rear , DVI-D output - rear , RGB output - rear , Speakers output - rear , Serial output - rear
- IR receiver
- Cables Included
- VGA cable
- FCC Class B certified, UL, TUV, cUL, CB, KCC, KC, ERP
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- Smart energy saving
- Width (Shipping)
- 118 cm
- Depth (Shipping)
- 16.5 cm
- Height (Shipping)
- 77 cm
- Weight (Shipping)
- 23.5 kg
- 0 °C
- 40 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
