Local Dimming technology allows brightness to be controlled in block units. This ensures brightness and clarity providing high picture quality. As a bonus, power consumption is reduced.
With narrower bezel and slimmer depth than those of competitors, you can save space more efficiently with WL30.
Brightness
It is designed to emit more light which means more luminance and contrast than general screen. -
Clear and vivid picture
Local Dimming technology allows brightness to be controlled in block units. This ensures brightness and clarity providing high picture quality. As a bonus, power consumption is reduced. -
Media player integrated solution
The solution integrated with media player foregoes the need for additional media players and allows you to cut down expenses. -
Narrow bezel and slim depth
With narrower bezel and slimmer depth than those of competitors, you can save space more efficiently with WL30. -
Landscape and portrait
Flexible usage with landscape or portrait display according to the display environment.
- LG 47WL30MS WL30MS Series - 47" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 47"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080p
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- Speakers not included
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 100 Watt
- Power Consumption Stand by
- 0.7 Watt
- Dimensions (WxDxH) - without stand
- 107.5 cm x 8.45 cm x 62.48 cm
- 12.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 100 Watt
- Diagonal Class
- 47"
- Commercial Use
- Series
- WL30MS Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 107.5 cm
- 8.45 cm
- 62.48 cm
- 12.3 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-reflection, 3H Hard
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1000:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 9 ms
- Image Sticking Minimization (ISM)
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- 1080p
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- External Speakers Amplifier Power (Total)
- 20 Watt
- On/off switch, Clear Voice II technology
- Connector Type
- HDMI , USB , LAN , DisplayPort input , DVI-D input , DVI-D output , Component video / RGB input , Audio line-in , Serial input , Speakers output , Remote control input
- FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.7 Watt
- Smart energy saving
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 107.5 cm x 8.45 cm x 62.48 cm x 12.3 kg , Panel with stand - 107.5 cm x 26.39 cm x 69.31 cm x 13.75 kg , Panel with stand and speakers - 107.5 cm x 26.39 cm x 69.31 cm x 14.5 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
