47" super narrow bezel video wall displays create visually stunning digital wall that is easily installed, maintained and managed. Brightness uniformity 80% ensures high-quality image delivered across displays. IPS panels have the better control of liquid crystal and in consequence, it allows you to watch the screen virtually at any angle.
Super narrow bezel
47" super narrow bezel video wall displays create visually stunning digital wall that is easily installed, maintained and managed. -
Higher brightness uniformity
Brightness uniformity 80% ensures high-quality image delivered across displays. -
Wide viewing angle
IPS panels have the better control of liquid crystal and in consequence, it allows you to watch the screen virtually at any angle. -
FREE SuperSign C for advanced color
Intuitive GUI in SuperSign C S/W allows to measure and adjust color and brightness instantly on display. Automatic white balancing of a video-wall display using a sensor.
- LG 47LV35A 47" Class (46.96" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 47"
- Diagonal Size
- 46.96"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- USB
- Included Accessories
- Remote control, IR receiver, carrying handle
- Voltage
- AC 120/230 V (50/60 Hz)
- 130 Watt
- Dimensions (WxDxH) - without stand
- 104.49 cm x 8.99 cm x 59 cm
- 16.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 130 Watt
- Diagonal Class
- 47"
- Diagonal Size
- 46.96"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Natural Mode
- Design
- Super Narrow Bezel Concept
- Dimensions
- Without stand
- 104.49 cm
- 8.99 cm
- 59 cm
- 16.5 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare, 3H Hard
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Backlight Life
- 50,000 hour(s)
- Certified for 24/7 Continuous Operation, Image Sticking Minimization (ISM), Input Labelling, compatible with SuperSign Software
Video Wall
- 225
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Connector Type
- HDMI input - rear , DVI-D input - rear , RGB input - rear , Serial input - rear , USB - rear , DVI-D output - rear , Serial output - rear , LAN - rear
- IR receiver, carrying handle
- Cables Included
- DVI cable , Serial cable
- FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- Auto On/Off
- Smart energy saving, auto power on
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 104.49 cm x 8.99 cm x 59 cm x 16.5 kg
- Width (Shipping)
- 118 cm
- Depth (Shipping)
- 16.5 cm
- Height (Shipping)
- 77 cm
- Weight (Shipping)
- 21.5 kg
- 0 °C
- 40 °C
- 10 - 90%
