LG Electronics 47LV35A 47" 1920x1080 12ms DVI HDMI USB LFD
Quicklinx: BN53WS00 Mfr#: 47LV35A
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£1,059.55 ex VAT
£1,271.46 inc VAT
47" super narrow bezel video wall displays create visually stunning digital wall that is easily installed, maintained and managed. Brightness uniformity 80% ensures high-quality image delivered across displays. IPS panels have the better control of liquid crystal and in consequence, it allows you to watch the screen virtually at any angle.
  • Super narrow bezel
  • Higher brightness uniformity
  • Wide viewing angle
  • FREE SuperSign C for advanced color
    Intuitive GUI in SuperSign C S/W allows to measure and adjust color and brightness instantly on display. Automatic white balancing of a video-wall display using a sensor.
LG 47LV35A 47" Class (46.96" viewable) LED display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
47"
Diagonal Size
46.96"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Max Number Of Screens
225
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
USB
Remote control, IR receiver, carrying handle
Voltage
130 Watt
104.49 cm x 8.99 cm x 59 cm
16.5 kg
Environmental Standards
ENERGY STAR Qualified
130 Watt
Diagonal Class
47"
Diagonal Size
46.96"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Natural Mode
Design
Super Narrow Bezel Concept
225
Dimensions
Without stand
104.49 cm
8.99 cm
59 cm
16.5 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 3H Hard
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Backlight Life
50,000 hour(s)
Certified for 24/7 Continuous Operation, Image Sticking Minimization (ISM), Input Labelling, compatible with SuperSign Software
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Connector Type
HDMI input - rear , DVI-D input - rear , RGB input - rear , Serial input - rear , USB - rear , DVI-D output - rear , Serial output - rear , Network - rear
DVI cable , Serial cable
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Auto On/Off
Smart energy saving, auto power on
Dimensions & Weight Details
Panel without stand - 104.49 cm x 8.99 cm x 59 cm x 16.5 kg
Width (Shipping)
118 cm
Depth (Shipping)
16.5 cm
Height (Shipping)
77 cm
Weight (Shipping)
21.5 kg
10 - 90%
BN53 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BN53 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.18
BN53 C2G 5m Select High Speed HDMI with Ethernet In Stock £20.65
Brand: LG
Price Range Ex VAT: 1000 - 1500
