Share your messages clearly. Featuring high-definition displays, LG commercial LED LCD monitors offer a sleek and innovative way entertain and communicate with your guests.
- LG 47LS55A 47" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 47"
- Commercial Use
- Yes - digital signage
- Titanium grey
- Platform
- webOS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 25
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Digital signage, HTML5 support
- Speaker System
- Speakers not included
- DVR
- 8 GB
- USB
- Included Accessories
- Remote control, IR receiver
- Voltage
- AC 120/230 V (50/60 Hz)
- 95 Watt
- Power Consumption Stand by
- 1 Watt
- Dimensions (WxDxH) - without stand
- 107.1 cm x 5.58 cm x 62.16 cm
- 12.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 95 Watt
- Diagonal Class
- 47"
- Commercial Use
- Platform
- webOS
- Video Processor
- Dual-Core
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor, brightness sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, DisplayPort
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 107.1 cm
- 5.58 cm
- 62.16 cm
- 12.2 kg
- Enclosure Colour
- Titanium grey
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Coating
- Anti-reflection, 3H Hard
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 11 ms
- Backlight Life
- 50,000 hour(s)
- Key lock, compatible with SuperSign Software
Video Wall
- 25
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
DVR
- DVR
- 8 GB
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance
- Speaker System
- External Speakers Amplifier Power (Total)
- 20 Watt
- On/off switch, Clear Voice II technology
- Connector Type
- 2 x HDMI input , DVI-D input , Serial input , LAN , USB 3.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in , Remote control/ambient sensor input , Speakers output
- IR receiver
- Cables Included
- HDMI cable
- FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- Smart energy saving
- Width (Shipping)
- 115 cm
- Depth (Shipping)
- 15.2 cm
- Height (Shipping)
- 71 cm
- Weight (Shipping)
- 15.9 kg
- 0 °C
- 40 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
