LG Electronics 43SE3KB 43" 1920x1080 12ms DVI HDMI USB LFD
Quicklinx: BN58WS00 Mfr#: 43SE3KB
  • 1080p
Detachable Logo
Portrait mode allows the logo to be positioned in the desired to be positioned in the desired setting.
USB Content Scheduling
Play and schedule contents with a USB connection-no server connection required.
Conformal Coating
Circuit board reliability is enhanced with conformal coating that protects against dust, iron powder, humidity and other harsh conditions.
Simple Network Management Protocol
SNMP support ensures convenient network management.
  • Portrait & landscape modes
    Both portrait and landscape scenes are available for the product.
  • Remote control via RS232C & network
    SuperSign embedded player with RJ45 interface allows easy content transfer and control via network.
LG 43SE3KB 43" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi (optional)
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SNMP support, detachable logo, No Signal image, SuperSign-w lite, SuperSign-c
USB
2 ports
Remote control, batteries
Voltage
60 Watt
96.96 cm x 5.4 cm x 56.39 cm
10 kg
Environmental Standards
ENERGY STAR Qualified
60 Watt
Diagonal Class
43"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Design
Slim Bezel Design
Protection
Dustproof
Dimensions
Without stand
96.96 cm
5.4 cm
56.39 cm
10 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Coating
Anti-glare, 3H Hard
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
Image Sticking Minimization (ISM), compatible with SuperSign Software, Enhanced Fail Over, 18/7 operation time
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
External Speakers Amplifier Power (Total)
20 Watt
Network & Internet Multimedia
Wi-Fi (optional)
Connector Type
HDMI input - rear , Serial input - rear , Serial output - rear , DVI-D input - rear , VGA input - rear , LAN - rear , Audio line-in - rear , Audio line-out - rear , 2 x USB - rear , Serial output - rear , Remote control input - rear
Batteries
VGA cable
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
Smart energy saving, WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 96.96 cm x 5.4 cm x 56.39 cm x 10 kg , Panel with stand - 96.96 cm x 19.3 cm x 62.22 cm x 12.3 kg
Width (Shipping)
105.2 cm
Depth (Shipping)
12.3 cm
Height (Shipping)
65 cm
Weight (Shipping)
12.6 kg
10 - 80%
BN58 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
