The SM5KB Series built-in Wi-Fi and SoC reduces the total cost of ownership and simplifies installation, which allows you to manage content more conveniently
Quad Core SoC
The high performance SoC can execute several tasks at the same time and provides smooth content playback. -
Detachable logo
Portrait mode allows the logo to be positioned in the desired to be positioned in the desired setting. -
webOS
The webOS 2.0 platform provides powerful and convenient tools to create content, including app development materials and support for various operating systems. -
Slimmer bezel
The thinner bezel allows a perfect fit for a sleek look. -
Cable management
The well-organized cable terminals in the back optimize available space. -
Built-in IR receiver
This receiver is very space efficient with features that are detachable and adjustable to suit your environment.
- LG 43SM5KB-B 43" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 43"
- Commercial Use
- Yes - digital signage
- Black
- Platform
- webOS 2.0
- Resolution
- 1920 x 1080
- Input Video Formats
- 720p, 1080i, 1080p
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Image Rotation, Smart SoC Built-in Signage, No Signal image, SuperSign-w lite, SuperSign-c
- Settings Cloning Capability
- Speaker System
- Speakers not included
- DVR
- Flash - 8 GB
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- 75 Watt
- Dimensions (WxDxH) - without stand
- 96.96 cm x 5.4 cm x 56.39 cm
- 10 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 75 Watt
- Diagonal Class
- 43"
- Commercial Use
- Platform
- webOS 2.0
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 96.96 cm
- 5.4 cm
- 56.39 cm
- 10 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare, 3H Hard
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1100:1
- Dynamic Contrast Ratio
- 4000000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Pivot, Certified for 24/7 Continuous Operation, Image Sticking Minimization (ISM), USB Cloning, Optional Touch Overlay, Enhanced Fail Over
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
DVR
- DVR
- Flash - 8 GB
Video Features
Media Player
- SD Memory Card
- USB Port
- USB Ports Qty
- 1
- Configuration
- 8 GB
- 8 GB
Remote Control
- Remote control
Audio System
- Speaker System
- External Speakers Amplifier Power (Total)
- 20 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- Wi-Fi Protocol
- 802.11n
- Connect & Share
- Screen Mirroring
- Connector Type
- HDMI input , DisplayPort input , VGA input , DVI-D input , Serial input , LAN , USB 3.0 , Audio line-in , Audio line-out , Serial output , DisplayPort output , Speakers output , Remote control/ambient sensor input
- Batteries
- Cables Included
- VGA cable
- FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 Watt
- Smart energy saving, WOL (Wake on LAN)
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 96.96 cm x 5.4 cm x 56.39 cm x 10 kg , Panel with stand - 96.96 cm x 19.3 cm x 62.22 cm x 12.3 kg , Panel with stand and speakers - 96.96 cm x 19.3 cm x 62.22 cm x 12.8 kg
- Width (Shipping)
- 105.2 cm
- Depth (Shipping)
- 12.3 cm
- Height (Shipping)
- 65 cm
- Weight (Shipping)
- 12.6 kg
- 0 °C
- 40 °C
- 10 - 80%
