Your basket is empty
LG Electronics 43" LED Large Format Display 1920x1080 Black 24/7 450 cd/m2
Quicklinx: C48TWS00 Mfr#: 43SM5KB-B
  • 1080p (Full HD)
The SM5KB Series built-in Wi-Fi and SoC reduces the total cost of ownership and simplifies installation, which allows you to manage content more conveniently
LG 43SM5KB-B 43" LED display
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Platform
webOS 2.0
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
720p, 1080i, 1080p
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Image Rotation, Smart SoC Built-in Signage, No Signal image, SuperSign-w lite, SuperSign-c
Settings Cloning Capability
Speaker System
Speakers not included
DVR
Flash - 8 GB
Storage Drive Capacity
8 GB
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
75 Watt
96.96 cm x 5.4 cm x 56.39 cm
10 kg
Environmental Standards
ENERGY STAR Qualified
75 Watt
Diagonal Class
43"
Commercial Use
Platform
webOS 2.0
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
225
Dimensions
Without stand
96.96 cm
5.4 cm
56.39 cm
10 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare, 3H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
4000000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Commercial Features
Pivot, Certified for 24/7 Continuous Operation, Image Sticking Minimization (ISM), USB Cloning, Optional Touch Overlay, Enhanced Fail Over
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
DVR
DVR
Flash - 8 GB
Video Features
Input Video Formats
720p, 1080i, 1080p
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
8 GB
Remote Control
Standard remote
Audio System
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
Network & Internet Multimedia
Wi-Fi, LAN
Wi-Fi Protocol
802.11n
Connect & Share
Screen Mirroring
Connector Type
HDMI input , DisplayPort input , VGA input , DVI-D input , Serial input , Network , USB 3.0 , Audio line-in , Audio line-out , Serial output , DisplayPort output , Speakers output , Remote control/ambient sensor input
Batteries
VGA cable
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Sleep
0.5 Watt
Smart energy saving, WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 96.96 cm x 5.4 cm x 56.39 cm x 10 kg , Panel with stand - 96.96 cm x 19.3 cm x 62.22 cm x 12.3 kg , Panel with stand and speakers - 96.96 cm x 19.3 cm x 62.22 cm x 12.8 kg
Width (Shipping)
105.2 cm
Depth (Shipping)
12.3 cm
Height (Shipping)
65 cm
Weight (Shipping)
12.6 kg
10 - 80%
