LG Electronics 43" 43LH604V Full HD Smart TV Premium Stand Design
Quicklinx: C3H2WS00 Mfr#: 43LH604V
  • 1080p
  • DVB-T
  • DVB-S
Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
  • Stylish design
    Enjoy masterfully manufactured design. The material is wrapped around your television providing excellent construction. This sleek housing adds a modern touch to any living room.
  • Virtual Surround
    More channels, better sound. High quality construction creates a surround sound effect, producing virtual audio channels. Surround your senses with sound from all angles.
  • Clear Voice III
    Clear Voice III enhances sound quality by separating voices from background noise to provide you with a clear and crisp listening experience. Focus on your content without distraction using Clear Voice III.
LG 43LH604V LH604V Series - 43" LED-backlit LCD TV - Full HD
LED-backlit LCD TV - Smart TV
Diagonal Class
43"
Platform
webOS 3.0
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
900 Hz Picture Mastering Index
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Picture Enhancements
ColourPrime
Speaker System
2 speakers
Sound Effects
Virtual Surround Plus
USB
2 ports
Remote control
Voltage
Energy Class
Class A++
Power Consumption (On mode)
35 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
51 kWh
97.4 cm x 7.94 cm x 57.1 cm
9.25 kg
Energy Class
Class A++
35 W
51 kWh
Diagonal Class
43"
Series
LH604V Series
Platform
webOS 3.0
TV Tuner Presence
Extended PVR
Video Interface
HDMI Ports Qty
3 ports
ColourPrime
Dimensions
Without stand
97.4 cm
7.94 cm
57.1 cm
9.25 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Time-shift, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
HbbTV
MPEG Profiles and Levels
MPEG4/MPEG2/HEVC
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Digital Audio Format
DTS-HD digital output
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Active noise reduction, Clear Voice III technology
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital video playback, WEB browsing
Wi-Fi, LAN
Wi-Fi Protocol
802.11n
DLNA
Connector Type
3 x HDMI , 2 x USB 2.0 , LAN , Composite video / component video input , Headphones , Digital audio output (optical)
Directive 2009/125/EC, EN 50564:2011, EN 50581:2012, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 61000-3-3:2013, EN 55022:2010, EN 55020:2007+A11:2011, EN 55013:2013, EN 62311:2008, EN 61000-3-2:2014, ETSI EN 301 893 V1.7.1, R&TTE Directive 1999/5/EC, IEC 62087-1:2015, EN 300 328 V1.8.1, EN 60065:2014
Power supply
Input Voltage
0.5 Watt
Dimensions & Weight Details
Panel without stand - 97.4 cm x 7.94 cm x 57.1 cm x 9.25 kg , Panel with stand - 97.4 cm x 19.9 cm x 62 cm x 9.45 kg
Width (Shipping)
106 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
66 cm
Weight (Shipping)
11.7 kg
