LG Electronics 32SE3KB 32" 1920x1080 12ms DVI HDMI USB LFD
Quicklinx: BN57WS00 Mfr#: 32SE3KB
  • 1080p
Detachable Logo
Portrait mode allows the logo to be positioned in the desired to be positioned in the desired setting.
USB Content Scheduling
Play and schedule contents with a USB connection-no server connection required.
Conformal Coating
Circuit board reliability is enhanced with conformal coating that protects against dust, iron powder, humidity and other harsh conditions.
Simple Network Management Protocol
SNMP support ensures convenient network management.
  • SNMP support
    Display remote management through SNMP is available in addition to RS-232C and other network protocols.
  • DisplayPort 1.2 daisy chain
    Display a high resolution UHD content in video wall through DP 1.2 daisy chain.
  • Self diagnosis
    Enables service engineers to recognize technical issues in the TV quickly and easily through a USB device. The TV stores any technical issues it encounters and can output it to a USB device.
  • Full HD
    LG provides a high quality graphic display resolution for good picture clarity and sharpness in detail.
LG 32SE3KB 32" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi (optional)
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SNMP support, detachable logo, No Signal image, SuperSign-w lite, SuperSign-c
USB
2 ports
Remote control, batteries
Voltage
50 Watt
72.94 cm x 5.55 cm x 42.89 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
50 Watt
Diagonal Class
32"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Design
Slim Bezel Design
Protection
Dustproof
Dimensions
Without stand
72.94 cm
5.55 cm
42.89 cm
5.4 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Coating
Anti-glare, 3H Hard
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Commercial Features
Image Sticking Minimization (ISM), compatible with SuperSign Software, Enhanced Fail Over, 18/7 operation time
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
External Speakers Amplifier Power (Total)
20 Watt
Network & Internet Multimedia
Wi-Fi (optional)
Connector Type
HDMI input - rear , Serial input - rear , Serial output - rear , DVI-D input - rear , VGA input - rear , LAN - rear , Audio line-in - rear , Audio line-out - rear , 2 x USB - rear , Serial output - rear , Remote control input - rear
Batteries
VGA cable
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
Smart energy saving, WOL (Wake on LAN)
Dimensions & Weight Details
Panel with stand - 72.94 cm x 5.55 cm x 42.89 cm x 5.4 kg , Panel with stand - 72.94 cm x 15.42 cm x 48.1 cm x 6 kg
Width (Shipping)
81 cm
Depth (Shipping)
13.2 cm
Height (Shipping)
51 cm
Weight (Shipping)
6.7 kg
10 - 80%
BN57 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
