Detachable Logo
Portrait mode allows the logo to be positioned in the desired to be positioned in the desired setting.
USB Content Scheduling
Play and schedule contents with a USB connection-no server connection required.
Conformal Coating
Circuit board reliability is enhanced with conformal coating that protects against dust, iron powder, humidity and other harsh conditions.
Simple Network Management Protocol
SNMP support ensures convenient network management.
SNMP support
Display remote management through SNMP is available in addition to RS-232C and other network protocols. -
DisplayPort 1.2 daisy chain
Display a high resolution UHD content in video wall through DP 1.2 daisy chain. -
Self diagnosis
Enables service engineers to recognize technical issues in the TV quickly and easily through a USB device. The TV stores any technical issues it encounters and can output it to a USB device. -
Full HD
LG provides a high quality graphic display resolution for good picture clarity and sharpness in detail.
- LG 32SE3KB 32" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi (optional)
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SNMP support, detachable logo, No Signal image, SuperSign-w lite, SuperSign-c
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- 50 Watt
- Dimensions (WxDxH) - without stand
- 72.94 cm x 5.55 cm x 42.89 cm
- 5.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 50 Watt
- Diagonal Class
- 32"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Design
- Slim Bezel Design
- Protection
- Dustproof
- Dimensions
- Without stand
- 72.94 cm
- 5.55 cm
- 42.89 cm
- 5.4 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare, 3H Hard
- Image Contrast Ratio
- 1100:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Image Sticking Minimization (ISM), compatible with SuperSign Software, Enhanced Fail Over, 18/7 operation time
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- External Speakers Amplifier Power (Total)
- 20 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi (optional)
- Connector Type
- HDMI input - rear , Serial input - rear , Serial output - rear , DVI-D input - rear , VGA input - rear , LAN - rear , Audio line-in - rear , Audio line-out - rear , 2 x USB - rear , Serial output - rear , Remote control input - rear
- Batteries
- Cables Included
- VGA cable
- FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- Smart energy saving, WOL (Wake on LAN)
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel with stand - 72.94 cm x 5.55 cm x 42.89 cm x 5.4 kg , Panel with stand - 72.94 cm x 15.42 cm x 48.1 cm x 6 kg
- Width (Shipping)
- 81 cm
- Depth (Shipping)
- 13.2 cm
- Height (Shipping)
- 51 cm
- Weight (Shipping)
- 6.7 kg
- 0 °C
- 40 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
