The industry leading panel featuring a Direct-LED back light creates stylishly slim monitors designed to fit perfectly into narrow spaces in retail shops while ensuring high energy efficiency. SuperSign embedded player with RJ45 interface allows easy content transfer and control via network.
Slim design
The industry leading panel featuring a Direct-LED back light creates stylishly slim monitors designed to fit perfectly into narrow spaces in retail shops while ensuring high energy efficiency. -
Remote control via RS232C & network
SuperSign embedded player with RJ45 interface allows easy content transfer and control via network. -
Cost-effective solution
No need for an additional media player.
- LG 32LS33A-5D 32" Class (31.55" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Diagonal Size
- 31.55"
- Commercial Use
- Yes - digital signage
- Titanium metallic
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- Speakers not included
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- Power Consumption (On mode)
- 45 W
- Energy Consumption per Year
- 65 kWh
- Dimensions (WxDxH) - without stand
- 73.1 cm
- 5.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 45 W
- 65 kWh
- Diagonal Class
- 32"
- Diagonal Size
- 31.55"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 73.1 cm
- 5.6 kg
- Enclosure Colour
- Titanium metallic
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 1200:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 9 ms
Stands & Mounts
- Flat Panel Mount Interface
- 200 x 200 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode
- Speaker System
- External Speakers Amplifier Power (Total)
- 20 Watt
- Balance control, Clear Voice II technology
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- HDMI input - rear , VGA input - rear , Serial input - side , LAN - rear , USB - side , Serial output - side , Speakers output - rear , Audio line-in - rear
- FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- Smart energy saving
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.1 cm 5.6 kg , Panel with stand - 73.1 cm x 20.7 cm x 48 cm x 5.8 kg , Panel with stand and speakers - 73.1 cm x 20.7 cm x 48 cm x 6.7 kg
- Width (Shipping)
- 81.2 cm
- Depth (Shipping)
- 13.9 cm
- Height (Shipping)
- 50.5 cm
- Weight (Shipping)
- 7.1 kg
- 0 °C
- 40 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
