Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
More channels, better sound. High quality software creates a surround sound effect producing virtual audio channels. Surround your senses with sound from all angles.
Clear Voice enhances sound quality by separating voices from background noise to provide you with a clear and crisp listening experience. Focus on your content without distraction using Clear Voice.
- LG 32LH510U LH510U Series - 32" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 32"
- Resolution
- 1366 x 768
- Display Format
- 720p
- Frame Rate & Enhancement Technology
- 300 Hz Picture Mastering Index
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 1 ports
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Picture Enhancements
- Active Noise Reduction
- Sound Effects
- Virtual Surround Mode
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- Power Consumption (On mode)
- 25 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 37 kWh
- Dimensions (WxDxH) - without stand
- 73.4 cm x 7.1 cm x 43.8 cm
- 4.5 kg
- Product Type
- Energy Class
- Class A+
- 25 W
- 37 kWh
- Diagonal Class
- 32"
- Series
- LH510U Series
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 1 ports
- Dimensions
- Without stand
- 73.4 cm
- 7.1 cm
- 43.8 cm
- 4.5 kg
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Direct-lit LED
- Eco Flower, Dynamic Color Enhancer, Picture Wizard III, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- Digital TV Service
- FREEVIEW HD
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Surround Mode
- Sound Effects
- Output Power / Total
- 6 Watt
- Clear Voice technology
Network & Internet Multimedia
- Supported Consumer Electronics Control (CEC)
- Simplink
- Connector Type
- Composite video / component video input , HDMI input , USB 2.0 , SCART
- Batteries
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.4 cm x 7.1 cm x 43.8 cm x 4.5 kg , Panel with stand - 73.4 cm x 17.2 cm x 47.4 cm x 4.7 kg
- Width (Shipping)
- 79.5 cm
- Depth (Shipping)
- 13.4 cm
- Height (Shipping)
- 50.5 cm
- Weight (Shipping)
- 6.2 kg
