LG Electronics 32LH510U 32" LED TV with Freeview HD
Quicklinx: CVDBWS00 Mfr#: 32LH510U
  • FREEVIEW HD
Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
More channels, better sound. High quality software creates a surround sound effect producing virtual audio channels. Surround your senses with sound from all angles.
Clear Voice enhances sound quality by separating voices from background noise to provide you with a clear and crisp listening experience. Focus on your content without distraction using Clear Voice.
LG 32LH510U LH510U Series - 32" LED-backlit LCD TV - HD
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Frame Rate & Enhancement Technology
300 Hz Picture Mastering Index
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Picture Enhancements
Active Noise Reduction
Sound Effects
Virtual Surround Mode
USB
Remote control, batteries
Voltage
Energy Class
Class A+
Power Consumption (On mode)
25 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
37 kWh
73.4 cm x 7.1 cm x 43.8 cm
4.5 kg
LED-backlit LCD TV
Energy Class
Class A+
25 W
37 kWh
Diagonal Class
32"
Series
LH510U Series
TV Tuner Presence
Video Interface
HDMI Ports Qty
1 ports
Dimensions
Without stand
73.4 cm
7.1 cm
43.8 cm
4.5 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Direct-lit LED
Eco Flower, Dynamic Color Enhancer, Picture Wizard III, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
Digital TV Service
FREEVIEW HD
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Surround Mode
Sound Effects
Output Power / Total
6 Watt
Clear Voice technology
Network & Internet Multimedia
Supported Consumer Electronics Control (CEC)
Simplink
Connector Type
Composite video / component video input , HDMI input , USB 2.0 , SCART
Batteries
Power supply
Input Voltage
0.3 Watt
Dimensions & Weight Details
Panel without stand - 73.4 cm x 7.1 cm x 43.8 cm x 4.5 kg , Panel with stand - 73.4 cm x 17.2 cm x 47.4 cm x 4.7 kg
Width (Shipping)
79.5 cm
Depth (Shipping)
13.4 cm
Height (Shipping)
50.5 cm
Weight (Shipping)
6.2 kg
