Run messages on up to 50 display screens in the form of a billboard without any additional hardware. Advertisements, information and broadcast content can be arranged on the same screen to attract attention and deliver specific messaging to your customer base.
- LG 32SE3B-B 32" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi (optional)
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SNMP support, detachable logo, No Signal image, SuperSign-w lite, SuperSign-c
- Speaker System
- Speakers not included
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- 50 Watt
- Power Consumption Stand by
- 0.7 Watt
- Dimensions (WxDxH) - without stand and speakers
- 72.94 cm x 5.55 cm x 42.89 cm
- 5.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- 50 Watt
- Diagonal Class
- 32"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Design
- Slim Bezel Design
- Dimensions
- Without stand and speakers
- 72.94 cm
- 5.55 cm
- 42.89 cm
- 5.2 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare, 3H Hard
- Image Contrast Ratio
- 1100:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Backlight Life
- 50,000 hour(s)
- Image Sticking Minimization (ISM), compatible with SuperSign Software, Enhanced Fail Over, 18/7 operation time
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Audio Controls
- Equalizer, balance
- Speaker System
- External Speakers Amplifier Power (Total)
- 20 Watt
- Clear Voice II technology
Network & Internet Multimedia
- Connectivity
- Wi-Fi (optional)
- Connector Type
- HDMI input - rear , Serial input - rear , Serial output - rear , DVI-D input - rear , VGA input - rear , LAN - rear , 2 x USB - rear , 2 x speakers output - rear , Remote control input - rear
- Batteries
- Cables Included
- VGA cable
- FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.7 Watt
- 0.5 Watt
- Smart energy saving, WOL (Wake on LAN)
- Limited warranty - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand and without speakers - 72.94 cm x 5.55 cm x 42.89 cm x 5.2 kg , Panel with stand and speakers - 72.94 cm x 154248.1 cm x 5.2 cm , Panel with stand - 6 kg
- Width (Shipping)
- 81 cm
- Depth (Shipping)
- 13.2 cm
- Height (Shipping)
- 51 cm
- Weight (Shipping)
- 6.5 kg
- 0 °C
- 40 °C
- 10 - 80%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
